Results 1 to 15 of 23
    Oct 2012
    Default KESS V2 CLON READ DME MSV80.0 BMW 125
    HELLO, CAN SOMEONE CHECK IF THIS FILE IS WELL READ AND IF APPLICABLE TO THIS ECU?
    HE USED, KESS V2 TOOL. CLONE
    BMW 125 218HP
    TRANSMITION AUTOMATIC
    ENGINE CODE : N52B30AE
    THANK YOU HOPE YOUR HELP.
    moky's Avatar
    Behind you
    if it's an MSV80 you can read but i think you will have problem for write it with fgtech or kess...
    Oct 2012
    I am using KESS V2 CLONE interface.
    also problems in writing?
    thanks for your reply.
    MSV70 - Fgtech euroclone didn?t write: error erase Flash and car didnt?start... sabe original fiel and works again...
    moky's Avatar
    Behind you
    i think yes,it can read and write MSD80 and MSV80 just read,you can see that msv not on list car so be careful at flash.fgtech read it too but no flash
    carmageddon's Avatar
    Italy
    BMW E93 320i 170 CV 07599881_07557745_OBD.rar
    if interest, i do this ecu with fgtech2 v48 via obd without problem, 30 min read, 30 min write.
  7. The Following User Says Thank You to carmageddon For This Useful Post:
    ascotauto (28th August, 2018)
    Oct 2012
    BOOT MODE IS POSSIBLE IN THIS ECU?
    ALGUIEN LO HA INTENTADO?
    THANKS
    Apr 2012
    Wonderland
    already flashed with kess v2 clone both msv80 and msd80 read and write ok
    ProTuner since 1999
  10. The Following User Says Thank You to atomiczen For This Useful Post:
  11. #9
    Oct 2012
    There is no way to recover in case of bad writing?
    excuse me but, I'm trying to clear all the doubts, to avoid serious problems.
    thanks.
  12. #10
    Quote Originally Posted by carmageddon View Post
    MSD80 K line?
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
  13. #11
    Italy
    now i dont remember if K or can
  14. #12
    It's K line normally, and V48 struggles with that.
  15. #13
    with fgtech euro clone write failed for E92 M3 i had to write ecu on bench out of car.
  16. #14
    Italy
    Quote Originally Posted by J_amb_o View Post
    i dont have problem to do this ecu.
  17. #15
    Quote Originally Posted by HsamehH View Post
    Wich ECU ? MSV70 ?
