Results 1 to 7 of 7
    Sep 2012
    Default bmw e90 steering lock fault
    gooday dk members
    i recently programmed a 2008 bmw e90 spare key with bmw multi-tool. the key programmed 100% as it starts the vehicle and works the central locking and unlocks the steering. however when you start the vehicle after a few secs . red warning light with a steering wheel and padlock symbol displays on screen and stays on. this just shows as a warning light because the steering does not lock once car is started. i tried owners old key and the same issue arises. the owner says the light was not present prior to the key being programmed.
    has anyone experienced this ? can anyone advise me on a solution ?
    try update cas sw
    Fallen's Avatar
    Sync cas and elv if not work update software in cas to latest version.
    Sep 2012
    fallen.... 100% correct. worked perfect.
  5. The Following User Says Thank You to MonSter911 For This Useful Post:
    Fallen (18th August, 2013)
    Nov 2011
    friend and friend
    hello good morning friend I have this tool, you can help me how to code second-hand keys (scrap).
    as coding
    thank you very much
    amir_82013's Avatar
    Hello
    I programmed one chip of ignition via OBD for one E90 2009 (330i) , Done
    But after key program only ACC on and no ignition and not start engine.
    This car lost all remote.
    I sync EVL and CAS but not solve problem.
    Message instrument cluster :
    Steering wheel lock:
    Electric steering wheel lock under strain.Steering wheel cannot unlocked.
    move the steering wheel to enable engine start.
    Voltage battery 13v
    - DTC CAS: A103: CAS: Immobilizer bus fault.
    - DTC AFS( Active Front Steering )TC 6140: AL: Redundancy comparison, driver's steering angle.
    Please help me . what is problem in your idea ?
    Nothern California
    how do you update cas to lastest version .What it exactly mean if u locksmith trying to make key for this car what else should you carry in your gear to get around situation like this
    Knowledge is the Key
