Results 1 to 5 of 5
    Aug 2013
    Default Help: Running NTSC games on PAL system using Priiloader
    Hello all,
    I bought my PAL Wii already soft-modded, and because I didn't know that the Nintendo updates mess with the mod, I went ahead and applied it. Of course, now my NTSC games won't run. I downloaded and installed home brew channel and then Priiloader. Now the disc channel can "see" the game, but when I try to start it, I get a black screen. The system is 4.3e.
    Below I've included which Priiloader hacks I've enabled and a syscheck log. Sorry if I'm missing something obvious; I'm a Wii noob, but I tried to do my homework first. Thanks in advanced!
    disabled Replace Health Screen with Backmenu
    disabled Re-enable Bannerbomb v2
    enabled Region Free EVERYTHING
    enabled Block Disc Updates
    enabled Region Free GC Games (No VM Patch)
    enabled Region Free Wii Games
    disabled Lock System Menu with Black Screen
    enabled Remove Diagnostic Disc Check
    disabled No System Menu Sounds AT ALL
    disabled No System Menu Background Music
    disabled No-Delete HAXX, JODI, DVDX, DISC, DISK, RZDz
    enabled Remove NoCopy Save File Protection
    enabled Region Free Channels
    enabled Force Disc Games to run under IOS249
    enabled Auto-Press A at Health Screen
    disabled Force Standard Recovery Mode
    disabled OSReport to UsbGecko (slot B)
    disabled OSReport to UsbGecko (GeckoOS, B)
    disabled Move Disc Channel
    enabled Block Online Updates
    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 2007.02.13
    Homebrew Channel 1.1.2 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x21
    Console ID: 169183430
    Boot2 v4
    Found 84 titles.
    Found 53 IOS on this console. 9 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 54321): Trucha Bug ES Identify Flash Access NAND Access
    IOS17 (rev 1032): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 54321): Trucha Bug ES Identify NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535 Info: hermes-v5.1): Trucha Bug NAND Access USB 2.0
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS224[37] (rev 65535 Info: hermes-v5.1): Trucha Bug NAND Access USB 2.0
    IOS236 (rev 54321): Trucha Bug ES Identify NAND Access
    IOS247 (rev 65535): Trucha Bug NAND Access USB 2.0
    IOS248 (rev 65535): Trucha Bug NAND Access USB 2.0
    IOS249 (rev 65280): Stub
    IOS250 (rev 65535): Trucha Bug NAND Access USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v65535
    Report generated on 2013/08/17.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Welcome to DK.
    If you trying to run an original NTSC game from the disc channel then that may cause a problem as all my game discs are PAL on my 4.3E.
    The only things you need to set in PriiLoader are Block Disc Updates, Block Online Updates and I enable Auto-Press 'A' at Health Screen everything else should be disabled. I have a mixture of PAL and NTSC games and they all play.
    You need to install some more wads. The easiest way to do this download ModMii6.2.7 and run it from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
    ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and install all 7 wads when you install the other wads.
    Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
    Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
    If you have a 4.3 then the Shopping Channel will not work. It will suggest you do a system update don't bother just install my RVL-Shopping-21
    Do another sysCheck to make sure everything installed correctly and post that.
    If that doesn't play any game without going black then the only other thing you can do in PriiLoader is enabled Region Free Everything.
    Keith
    2010 Golf GTD (170)
    Aug 2013
    Hi Keith, thanks for your response!
    I think I might have messed it up. I didn't understand that a mod is different from a wad. I downloaded and ran ModMii and it downloaded 18 files, and I assumed the v5 Mod was included, so I went ahead and installed the wads. When I tried to run the game, I got a blue screen with Error #2. So I tried to uninstall the wads with ModMii and it refused, tried to reinstall and it refused too.
    When I finally realized IOS236 Installer v5 Mod was something that had to be downloaded separately, I went and googled it. I found it here. I installed IOS 236 v5 Mod successfully and then used the YAWM to retry installing the same wads I got with ModMii. That worked, but only to get back where I started. Now the disc channel sees the game but I get a black screen when I try to run it.
    Oh, as for Priiloader, I disabled everything except the four you mentioned: Block Disc Updates, Block Online Updates, Auto-Press 'A' at Health Screen, Region Free Everything.
    Below is the latest syscheck after all that. ModMii tells me it's up to date now.
    Any thoughts?
    Region: PAL
    Hollywood v0x21
    Boot2 v4
    Found 88 titles.
    Found 56 IOS on this console. 4 of them are stub.
    IOS9 (rev 1034): No Patches
    IOS11 (rev 16174): Trucha Bug NAND Access
    IOS20 (rev 16174): Trucha Bug NAND Access
    IOS30 (rev 16174): Trucha Bug NAND Access
    IOS36 (rev 3608): No Patches
    IOS40 (rev 16174): Trucha Bug NAND Access
    IOS50 (rev 16174): Trucha Bug NAND Access
    IOS52 (rev 16174): Trucha Bug NAND Access
    IOS60 (rev 16174): Trucha Bug NAND Access
    IOS70 (rev 16174): Trucha Bug NAND Access
    IOS80 (rev 16174): Trucha Bug NAND Access
    IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    BC v6
    MIOS v10
    Aug 2010
    England
    Quote Originally Posted by BrownCookie View Post
    It appears you can't follow simple instructions I gave you which are exactly the same as I give everyone. After you have run ModMii you add all files and folders to the SD card. Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. ModMii makes a apps\IOS236-v5-Mod folder thats IOS236 Installer v5 Mod that is what shows in Homebrew. Then you install all wads with Multi Mod Manager (MMM) job done.
    ModMii won't uninstall anything.
    I didn't mention 4 things to set in PriiLoader really only 2 Block Disc Updates, Block Online Updates I enable Auto-Press 'A' at Health Screen everything else should be disabled.
    I said at the end
    Quote Originally Posted by Keithuk View Post
    if that doesn't play any game without going black then the only other thing you can do in PriiLoader is enabled Region Free Everything.
    Now that sysCheck looks exactly the same as mine so you must have installed everything in the end.
    You don't say which USB Loader your using but USB Loader GX 3.0 has a setting to disable the Error 002.
    Going back to your original problem of playing NTSC discs in a PAL Wii I've never done this because all my discs are PAL. The way around this would be to install that game disc onto an external USB hard drive (preferably mains powered). Put the disc in and run USB Loader GX and click on the round button botton left. Providing there is enough space on the drive it will make an image of that game disc onto the drive then you run the game from USB Loader GX as I do with my mixture of PAL and NTSC games and they all play.
    If you running USB Loader GX then its easier to install a Forwarder Channel so you have a link on the Wii menu. USB Loader GX if you don't have this on your SD card download USBLoader_GX_V3_0_AllinOnePackage_IOS249.zip and add it to the SD card.
    USB Loader GX - UNEO Forwarder Channel V5.1 add USB Loader GX-UNEO_Forwarder_5_1_AHBPROT.wad to the wad folder on the SD card and installl it with MMM.
    Keith
    2010 Golf GTD (170)
  5. The Following User Says Thank You to Keithuk For This Useful Post:
    BrownCookie (18th August, 2013)
    Jan 2014
    Welcome to DK.
    Thanks so much for that. All that worked, and at the end, enabling 'region free everything', got Arc Rise Fantasia working. Much appreciated
