Results 1 to 4 of 4
    Budapest,Hungary
    Default Renault ClioII 1.5dci egr off please
    Hello!
    I need to some solution Renault ClioII 1.5 dci EGR off.
    It is possible?
    Delphi
    2005
    48KW
    Thanks.
    Nov 2012
    France
    your file egr off
    clio_ori_egr_off.zip
    try and report!
    Apr 2012
    wolomin poland
    hi i was testing your mod for clio idk why galetto shows me gm delco ecu in this flash mine ecu is 8200389169
    8200331477
    8200318851
    galletto cant close ecu after flash on your file . this is mine org flash
    compare it for further checkAttachment 216323
    best regards
    this is proper egr off for ori file that is above and map pack for winols found on other forum and its correct . maybe it will be usefull for somebody
    Attachment 216377
    Attachment 216378
  4. The Following User Says Thank You to lonczyn For This Useful Post:
    Nio (2nd September, 2013)
    Dec 2016
    Hello.
    I have the same "GM DELCO" ecu reported, instead of DELPHI.
    I am trying to remap with some 40kb image found online, and i get the same ecu closing problem, and no start.
