Can any body tell me how to reset service light on a Ford Focus 2011 1-6 tdci
thanks in advance
Scouse
thanks in advance
Scouse
autodata dosnt show a reset , have u tried the older reset
Service indicator
Ensure all doors are closed.
Switch ignition ON.
Simultaneously fully press and hold brake and accelerator pedals for approximately 15 seconds.
Service interval indicator flashes or "service oil reset complete" is displayed.
Release pedals.
Service interval indicator is extinguished when reset complete.
Switch ignition OFF. Wait at least 2 minutes.
Switch ignition ON and check service interval indicator or service message is extinguished.
or have u looked on the menu buttons on the steering wheel
or this
Resetting the oil life monitoring system
1. Turn the ignition key to the on position. Do not start the engine.
For vehicles with push-button start, press and hold the START/STOP
button for two seconds without pressing the brake pedal. Do not attempt
to start the engine.
2. Press both the accelerator and brake pedals at the same time.
3. Keep both pedals fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be
displayed.
5. After 25 seconds, the Service: Oil reset complete message will be
displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be
displayed.
8. Rotate the key to the off position.
For vehicles with push-button start, press the START/STOP button to
turn the vehicle off completely.
super jumbe (23rd September, 2013)
Thanks for your reply, I will try in the morning
Ta Scouse
Thanks smirnoff_rules worked with no problems
Scouse
