Results 1 to 5 of 5
    Jul 2013
    Unhappy How do I save Cccam.cfg or display Cccam.cfg on F3 box.
    I am trying to see/save Cccam.cfg from F3 box, but evry time I save Cccam.cfg it save's 0kb.
    Member durasoft's Avatar
    Aug 2008
    Hi Kivish,
    Make sure your USB is formatted fat32
    Go into menu and select Dump By USB
    Change Dump Mode to Misc Files then press Select & Dump
    Select No.3 CCcam.cfg and press ok so it ticks it.
    Then press the Yellow Button to save it to your USB Stick
    It then should say 100% "Dump All Finished. press "info" key for result.
    That's your Line backed up hopefully.
    It's only 1 line of data so it shouldn't be a large file anyway about 1k
    I use NotePad to open the file to view it or edit it.
    Hope this helps you out.
    Regards Tony
    Humax FoxSat-HDR
    Great HD/SD Box with 500GB HardDrive
    Manhatton HH-120 42E-30W
    Triax 88cm 0.3db
    SKYBOX F3
    HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
    Intel Core i7 2600K@4.2GhZ
    MSI R7970 Twin Frozr Boost Edition
    Nov 2008
    Quote Originally Posted by durasoft View Post
    Hi Kivish,
    Regards Tony
    I have the same problem. I too have a blank file with 0 bytes. There is nothing to view with Notepad, only an empty page??
    Member alienkargo's Avatar
    Jan 2014
    try deleting it and putting it back on from where you backed it up on your pc.
    Nov 2008
    Quote Originally Posted by alienkargo View Post
    I re-formatted usb stick to fat32, dumped new cccam.cfg onto stick and then re-inserted into pc, still nothing to view. and shows 0 bytes. I don't know what else to try.
