Results 1 to 8 of 8
    Apr 2013
    RO-IS
    Default RCD310, RCD510 car radio decoding tool
    Hi all, how to decode RCD 310,510 this tool it not free! here: RCD310, RCD510 car radio decoding tool
    • VW RCD310 LOW EU (7647201360, 1K0 035 186 AA) car radio: read/write 95128 EEPROM, read code, change code, repair damaged radio (if radio original EEPROM file is lost), reset "wrong code try" timer;
    • VW RCD510 MID EU car radio: read/write 95128 EEPROM, read code, change code, repair damaged radio (if radio original EEPROM file is lost), reset "wrong code try" timer;
    Dec 2010
    Russia
    This tool does not support MCU NEC70F3353..!
    VWZ1Z2_RCD 310 LOW EU G+ UP2 BVX_5M0 035 186J_7 640 212 360
    and other models
    Calc codes from serial FORD V-series from FORD dealer login
    Wegrow, Poland
    Support RCD310 with NEC70F3353 . You must read code with "SEAT SUPER LOW Blaupunkt (70F3353 - ST95128) Radio Tool" finction. I try, work.
  4. The Following User Says Thank You to fabi For This Useful Post:
    mobilart (10th September, 2013)
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Romania
    Quote Originally Posted by fabi View Post
    Hi to member fabi! This tool is a stand alone tool or must attached to some basic tool?and can calculate algo for rcd310 nec+95128?
    Thanks!
    Wegrow, Poland
    This is stand alone tool. No need carprog to work.
  8. The Following User Says Thank You to fabi For This Useful Post:
    attilaa0 (12th September, 2013)
  9. #7
    Romania
    Ok !Thanks ,but can calculate code ?Or only read out the dumps of MCU and eeprom?
  10. #8
    Wegrow, Poland
    This tool can read/write eeprom, read/change code and repair checksum in eeprom.
    This tool work only with carradio, not work with dump.
  11. The Following User Says Thank You to fabi For This Useful Post:
    attilaa0 (13th September, 2013)
