Results 1 to 4 of 4
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    Default How do i install Autocom/Delphi onto HP PDA???
    Hi Guys (and the odd Gal)..............got a question about PPC installation of Autocom/Delphi onto a HP IPAQ PDA as used by Original Autocom/Delphi units.....how do I install 2013.1 for cdp+/new vci ?????
    Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
    Dec 2012
    load the software as normal on virtual drive or dvd select ppc version connect your device to pc then run software it will select install via active sync an install
    product id isCars ID: a-710-532
    Trucks ID: a-710-785
    here's a list of compatable pda's
    Tested Pocket PCs on which you can run the latest software:
    HP iPAQ 114 Classic
    HP iPAQ 214 Enterprise
    HP iPAQ hx2190
    HP iPAQ hx2490
    HP iPAQ hx2790
    HP iPAQ hx2110
    HP iPAQ h2200
    HP iPAQ h2210
    HP iPAQ h1940 (some early h1940 may need to upgrade ROM version to newer than 1.00.03)
    HP iPAQ rx3715
    Fujitsu Siemens Pocket LOOX 420
    HP iPAQ h6340
    Dell Axim X50 416 MHz
    QTEK S200
    Acer n300
    Tested Smartphones on which you can run the latest software:
    Sonyericsson xperia X1
    HTC Touch HD
    Tested Pocket PCs on which the software work but with comments:
    Acer n30 - Very slow (not recommended).
    QTEK 9100 - Supports only miniSD-card, which is not included toghter with the CDP package.
    Tested devices on which the software does NOT work
    HP iPAQ hx4700
    HP iPAQ h5550
    HTC Touch Diamond
    M3 Mobile
  3. The Following 2 Users Say Thank You to gazvts For This Useful Post:
    asiprens64 (20th December, 2013), darrenhyland (10th September, 2013)
    heteromies
    Guest
    Is there now what interfaces for latest soft available and tested?
    Jun 2018
    is there any new info? i own a "Dell axim v51" and a autocom clone. but i cant install it on the PPC....
