Hey guys, i need a little help with IMMO off for this file, please.
Bosch 0261 203 075.rar
Thx in advance!
Thx in advance!
please take the bottom alloy base off the ecu, and post a picture of the location of resistor R615...
AND ILL TELL YOU WHAT TO DO ...
The difference between men and boyz...Is the price of there Toyz.
LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
Or take this old version with 27c256.
Program attached file in a 27c256 and put pin 1 of the eprom in pin 3 of the socket.
So you have 4 pins open in the socket at the left.
Rockiii (4th October, 2013)
yeah...I guess that ill work to easy.....
if it does have a 32 pin dil.........
I will take a pic in the afternoon.
It has 32Pin 27C256 on it.
sounds good!
we will sort it out after the pic....
Here's the pic
Ok
youre ecu is different...
so please use Easytech option...
program it as mentioned in a 28 dil chip and set back 4 holes on notch side of eprom...
you will be fine...
Fuuuu.... just right now I've checked again. Its an 28PiN 27C256 already build on.
This would explain why its different to your ecu, right?
What to do in this case?
Ok...
please pm me your email...
And last.. The motor does crank over? Right?
if not i need to tell you what to do there too...
Can you read and upload your dump again?
What I see is corrupt somehow.
If ecu has 28pin 27c256 pretty sure it is without immo version.
Re-uploaded the file in the first post.
I checked the VIN and in the parts list is the SA Code for EWS.
Did you check my dump?
Try this, its original from a non EWS.
075x.rar
Thanks, working well!
