Results 1 to 11 of 11
    Oct 2013
    Default dreambox control center error 10057
    hi people im using dm500s with darkstar 2 image
    usually it works fine with Dreambox-CCcamconfig-Editor but recently cant connect to server
    when trying to put new cline on box
    could be my new router be the problem?
    i checked router and dhcp is enabled
    so i open dremabox control center
    when i clik on direct crossover it says error 10057
    when i cliked on switch/hub pc gooes green hub green but dreambox red says check ip dreambox i checked and its correct
    when i cliked router and reconnect it error 10057
    wat should i do next/
    Oct 2013
    then search ip dcc result was .1.254 name mitrastar.home should the name be dreambox or sumthn?
    check ip on tv screen says 1.1
    accepted thaat and cliked reconect
    Telnet Connected
    Telnet Disconnected
    Telnet login incorrect!
    FTP Connected
    FTP Disconnected
    Oct 2013
    Telnet Connected
    Telnet Disconnected
    FTP Connected
    FTP Disconnected
    Oct 2013
    Telnet Connected
    Telnet Disconnected
    FTP Connected
    FTP Disconnected
    Oct 2013
    dreamboxtools.exe im trying that now
    it appears it picked u ip .1.5 like i changed it to
    Oct 2013
    Comprehensive
    Oct 2013
    ok i ticked dhcp and rebooted .. i opened dmboxtools and ip is .1.2
    but on tv it sayd ip is .1.1 ffs!
    Oct 2013
    Oct 2013
    connection timed out!
    lil help please
    Oct 2013
    bump anybody///
    Oct 2013
    DHCP Server State
    DHCP :
    Enable Disable DHCP Relay
    DHCP Server Lease Time
    Days Hours Minutes
    DHCPv6 Configuration
    DHCPv6 State :
    DHCPv6 Server
    When any of the LAN clients on your network want to be always assigned fixed IP addresses, add a static lease for each such LAN client. You may need to know the MAC addresses of the clients in advance in order to process the set-up quickly
    Static DHCP ;
