Results 1 to 10 of 10
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default focus 2008 outside temperature reading -60 after battery change
    focus outside temperature reading -60 after battery change , just put an abs unit on this and the temp is out , l know its not the abs .. l have read this is normal and you have to wait afew hours for it to reset . anyone had this ?
    Ashraf6119's Avatar
    UK
    I don't think that's normal after disconnecting the battery, -60 will only show if the wiring to sensor is broken or the sensor is faulty...............
    The sensor is normally located be-hind the front bumper on passenger side you can take a quick look at the connections...........
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Mar 2008
    birmingham
    Spain
    I don?t know why this happening in Ford cars, but using a memory saver the next time will help to avoid that.
    Regards.
    Mar 2008
    birmingham
    did have my obd one on but didn't know the thing had stopped working need to send it back . seally crap
    Sent from my iPhone 5
    Ashraf6119's Avatar
    UK
    The one on Ford Forum did reset by itself after 2 to 3 days so I think even yours must have been reset by now if not then just give it a day or two to see if it does........
    Thanks Ash
    genius76's Avatar
    Dec 2012
    Lowestoft
    Quote Originally Posted by Ashraf6119 View Post
    Mate his know it here more discus not help thread
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    Ashraf6119's Avatar
    UK
    My Friend read his first post properly and you will know what is he asking for..............
    Thanks Ash
    Mar 2008
    birmingham
    customer called this morning and its back to normal ... cheers
  10. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    Ashraf6119 (16th October, 2013)
  11. #10
    Meat-Head's Avatar
    Why is that, here on the WORLDS best website, it's so BUSY you miss stuff.
    Yes, had it before, agree, read on an INFERIOR forum leave it for an hour or so.
    Been there, done that, don't worry be happy.
    Just when it's in Farenheight, need to google that.
