Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    Oct 2012
    Default peugeot 207 electric steering
    hello
    I have a problem on a peugeot 207 in electric power steering.
    When I connect the cable obd says it has internal error.
    Someone can help me? Anyone have a virgin dump?
    eprom : 95160
    ref: 6700002168
    q003ta0772ze 9z14
    jtekt corporation
    diag1001's Avatar
    Sep 2012
    dellys algeria
    hi this is the problem your derection does not work or what?
    this is not working you not break your head this is a problem of transistor was bursting in moteure jai deja vue plusur times on the same car
    Allahu Akbar Sobhan Allah
    Oct 2012
    The steering do not work. Where is the trans?stor? Do you repair it?
    diag1001's Avatar
    Sep 2012
    dellys algeria
    hi here is the photo transistor you find one or two bursting
    Oct 2012
    I find no such transistor
    the electric power steering is in this photo
    Meat-Head's Avatar
    how cool is that
    l
    ooking at the photos bet it was a pig to get to bits.
    looking at that then gues the blown fet is on the back side of that 'spiky' heatsink.
    Hello
    I'm in the same situation. I don't understand what are the transistor burned.
    Are on this card? in the attached picture.
    Thank you.
    juan andres's Avatar
    Quote Originally Posted by sdipi View Post
    Hello
    Thank you.
    Hi, need solution? Thanks
    Enviado desde mi XT1580 mediante Tapatalk
    Dec 2010
    resold the processors and gets the problem solved
    Quote Originally Posted by Rui Ferreira View Post
    it does not work, any suggestions
    Solded
    Aug 2015
    Hello, I am trying to solve this problem, I have the C1414 fault code. Changing the micropocessor worked? or do we have to change the transistors?Greetings.
  13. #13
    Aug 2015
    Greetings.
  14. #14
    Sep 2015
    C1414 is a problem of driver brushless motor.
    you have to reball driver that are vs pink square in the dissipator side
  15. The Following User Says Thank You to Sauro1978 For This Useful Post:
    centralina (23rd November, 2020)
  16. #15
    Aug 2015
    Default c 1414
    Please, could you indicate where exactly the driver is that I have to change for error c1414,
    Thank you,
