My friend has had to put a second hand fuel pump on his vauxhall/opel combo van. He says it won't start now. Does anyone know if it will need coding and if so how?? I have opcom and autocom and he has the code key. Thanks. Dave.
Hi, no needed coding, with OpCom you can activate the pump.
Regards from Chile
what is the engine code, did you read DTC's ?
hi dave
i got called to a combo other month with same problem
wouldnt start
they replaced fuel pump
still same
look on the back of the engine from under the car you need to take the fuel pump ecu off and split it open
there will be a few dry joints in here
do your thing and reassemble and replace
the car will fire up then
dave
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKSits only polite....
Yes common fault on edu unit on the 1.7 engine
