Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    Default HOW TO REPAIR AUTOCOM CDP+ (FIRMWARE UPGRADE - VCI not FOUND)
    LINKS ARE UPDATED
    I have some problems with two different types AUTOCOMS CDP+. PCB was different type and both have a problems with message VCI not found. They both using same procesor STM32F205ZGT6 same shematic but different layout. Autocom with 2 PCB (main pcb + relay pcb) is better quality from autocom with only one double layer PCB. The second one has already printed test points to make connections to upgrade firmware. To repair your broken Autocom with this kind of processor is really easy only you need:
    - wires
    - solder iron
    - Flash_Loader_Demonstrator
    - firmware
    - some electronic skiils
    Steps are:
    1. Install Flash_Loader_Demonstrator
    2. make wire connection between VDD (pin1 from J400) and pin138 BOOT0 from STM32F20XXX - for Autocom pcb V 3.0 or between TP102 (VDD) and TP206 - for Autocom class B
    3. put a switch between pin9 and pin10 from J400 (this connection is needed to join short time NRST to GND - make resset)
    4. connect Autocom to car (or external 12v) and USB to computer
    5. start Flash_Loader_Demonstrator and dont change anything in settings just select yout VCI port number
    6. connection wire is between VDD and BOOT0 (step2) all time while upgrating firmware
    7. After Flash_Loader_Demonstrator window is appear then made short connection between pin 9 and pin 10 from J400 (look at pictures)
    8. If everything is OK then next window will be avaliable in Flash Loader Demonstrator
    9. When connection with MCU is avaliable, you need choose type of MCU 1024K
    10. Select your firmware ex. 2012.3.bin from download to device option and global erase
    11. Click next and wait about 7 min for uploading your firmware to Autocom
    12. After uploading firmware finished just disconect Autocom from OBD2 and USB and connect it again and make test and you will be suprised your Autocom is live again
    All files and documentation is here
    I hope this post was helpfull for all people having problems with Autocom chinese clones.
    We can't help everyone, but... everyone can help someone!
  2. The Following 67 Users Say Thank You to makadam For This Useful Post:
    adrianoo (1st February, 2022), AlexOne1013 (25th April, 2021), alfons37 (27th November, 2013), alladdin205 (16th December, 2013), AndyCZ (18th February, 2017), asiprens64 (20th December, 2013), beongo (8th July, 2019), biela (29th June, 2022), Big11 (24th February, 2019), bmc (13th November, 2018), brchip (15th March, 2018), busaman (24th March, 2014), chli1976 (17th January, 2014), Col19 (6th March, 2021), dan1gsm (28th February, 2017), daniersms (16th February, 2018), Darek90 (9th May, 2024), dema2 (31st July, 2022), Dunker (3rd December, 2013), dzt1399 (1st January, 2024), ecufix (7th March, 2018), fega99 (10th March, 2023), gecibogar (7th January, 2019), giani03 (18th March, 2015), godoreba (3rd March, 2018), jakesman (2nd September, 2018), jjrp255630 (28th November, 2013), jnoroeste (27th November, 2013), karageorgos (30th June, 2022), Kryss (12th June, 2020), Mac Gyver (21st November, 2013), MAYQUAD (9th February, 2015), mdelu (7th May, 2021), metaleks (10th December, 2021), mexanico1971 (17th January, 2014), miltas (26th June, 2019), mintika (29th April, 2023), MJRVR (20th November, 2013), montonero (25th January, 2014), parkoto (16th July, 2019), rankan (6th March, 2021), reasson (19th March, 2022), Renato95 (18th November, 2023), Rog3rD (22nd June, 2016), roman66 (21st August, 2024), ruffles1986 (20th November, 2013), samyy (9th April, 2017), Sarkan (12th February, 2015), seal777 (9th October, 2022), sep382 (25th April, 2019), sisox (22nd March, 2017), Stelaras26 (15th February, 2018), stormb (17th January, 2014), t1tan1 (21st November, 2013), tech12 (24th November, 2013), Tenea (23rd December, 2024), titinou67 (31st January, 2023), titoun (1st October, 2014), tomxx (2nd March, 2022), uko76 (7th February, 2019), v11 (2nd August, 2018), vasycara (29th November, 2013), viking6791 (18th July, 2021), Wsergik (21st August, 2022)
  3. #2
    Sep 2013
    California
    Thanks for sharing. really helpful
    meteor80's Avatar
    Already was posted.
    And Vci not found is when you don't disable internet connection.
    Wysłane z mojego Lenovo A820 przy użyciu Tapatalk now Free
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  5. The Following User Says Thank You to meteor80 For This Useful Post:
    titoun (9th August, 2016)
  6. #4
    Nov 2010
    EUROPE
    Quote Originally Posted by meteor80 View Post
    Already was posted.
    If u find anywhere on DK this hardware version with two pcb and without test points printed on pcb, i will delete this post.
    And message VCI not found is appear every time when driver is installed and work Ok, usb-serial converter on autocom work, and firmware or ARM is not working as should be.
    What message you espect to appear, maybe unit explain to you in details what is the problem ?
    Sent from my GT-I9100P using Tapatalk
  7. The Following 2 Users Say Thank You to makadam For This Useful Post:
    brchip (15th March, 2018), meteor80 (27th November, 2013)
  8. #5
    meteor80's Avatar
    Of course you arę right about dual pcb autocom, but when you have VCI not found it is propably because serial number is blacklisted and software connected with server.
    Anyway thanks for dual pcb solution :-)
    F.Kiepski.
  9. #6
    I have autocom with gold case and two PCB V3.6 and the software doesn't recognize it. In device manager i can see it but the sofware doesn;t recognize it.
    With the activation tool I can't see the serial number. Any help wi'll be useful. I don't have a programmer so I search for an OBD programming solution.1.jpg2.jpgWP_000086.jpgWP_000087.jpg
  10. The Following User Says Thank You to alladdin205 For This Useful Post:
  11. #7
    I have autocom with gold case and two PCB V3.2 and the software doesn't recognize it. In device manager i can see it but the sofware doesn;t recognize it.
  12. #8
    Quote Originally Posted by alladdin205 View Post
    Maybe wrong software setup information (for cdp+ instead of cdp pro)?
  13. The Following User Says Thank You to paro44 For This Useful Post:
  14. #9
    Dec 2012
    Have you tested this while connected to 12v ?
  15. #10
    I.have.connected.to.12V.
    Still.no.VCI.found.
    Any.ideas?
  16. #11
    Dec 2012
    have you used the correct S/N ?
  17. #12
  18. #13
    I've used the corect S/N. Reinstalled the operating system and autocom software. Same problem. When i connect it to the cars the relays are not clicking. I've atached some images above with the errors when the autocom is connected to car. On relays i have only 2,25 V (marked with black on PCB). Grom what i have read there must be 5 V.
  19. #14
    Can someone direct me to a solution, pls?
  20. #15
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Maybe the best solution is bay new interface, clone is cheap, and save your time
    Enviado desde mi GT-I8260 mediante Tapatalk
  21. The Following 2 Users Say Thank You to ruffles1986 For This Useful Post:
    sarunelis83 (7th November, 2016)
