Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    west mids, uk
    Quote Originally Posted by keysph View Post
    Have you try this?
    http://www.digital-kaos.co.uk/forums...4/#post1469497
    And there was another procedure that involved engine bay but can't find it
    tried this too
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  2. #17
    EU
    all of them have 16 pin and 10 pin socket,just look behind 16 pin socket there is white 10 pin socket(attached to same metal plate)
    16 pin obd is for key programming and 10 pin is for remote.
    regards
  3. #18
    west mids, uk
    car is coming back on monday so will check again, even though dont have any 10 pin equipment for this.
    ninja
  4. #19
    foxtec800's Avatar
    ninja, i have not tried it with mine, but maxidas SAYS it covers the kia/hyundai code saving do you know someone with one of them. or a g-scan
    other than them don`t think you can do it without diagnostic tool
  5. #20
    west mids, uk
    I have made keys for hyundai's before, but never done remoptes on them, also, if i remember, I could only program 1 key, not 2, only takes first key everytime
    ninja
  6. #21
    Aug 2010
    ninja, i done this 2x RM program for the customer not long ago it work ok,it depend what system u working on,may be u can try the two option below.
    . Remove the dash shroud. (4 screws)
    2. Behind the ashtray is the ETACS module, it's the computer that controls the alarm, turn signals, basically everything that doesn't make the car move.
    3. There’s a very small DIP switch somewhere on the module, with a 1 and 2. Flip the corresponding switch for the remote, if you're replacing #1, flip the switch with the 1. Might as well do both, but one at a time.
    4. After you flipped the switch, press a button on the remote. Flip it back. Now do the other switch and remote.
    ETACS= Electronic Time Alarm Control System *
    1. ENSURE MEMORY SWITCH IS IN OFF POSITION.
    2. TURN IGNITON TO ON
    3. WAIT 5 SECONDS, SET MEMORY SWITCH TO SET POSITION.
    4. PUSH REMOTE LCOK BUTTON TO SEND CODE TO ALARM SYSTEM CONTROL MODULE
    5. TO PROGRAM 2ND REMOTE: PRESS 2ND REMOTE LOCK BUTTON
    6. SET MEMORY SWITCH TO OFF POSITION
    7. TURN IGNITION TO OFF
    8. CONFIRM PROGRAMMING BY LOCKING AND UNLOCKING CAR WITH BOTH REMOTES
    11. REFIT ALL COMPONENTS IN RECERSE ORDER OF REMOVALONLY 2 REMOTES CAN BE PROGRAMMED AT ONCE
    good luck
    *** SOME YEARS REQUIRE DIAGNOSTIC PROGRAMMING ***
  7. The Following User Says Thank You to bob carr For This Useful Post:
    armpower (28th April, 2016)
  8. #22
    west mids, uk
    my problem is locating the module, if i could find it then i could do it, but this is the first time i have heard about a module behind ash tray, will try tomorrow, thanks.
    ninja
  9. #23
    west mids, uk
    UPDATE:
    Got this sorted in the end, the ONLY tool that would add 2 transponder keys was SBB!!!
    I found the remote control receiver box, moved dip switch to 'SET' and programmed both remote controls
    ninja
  10. #24
    Feb 2016
    Hi. How to program remote for 2009 year santa fe?
    Fvdi and ck100 can't do it, maybe is some tutorials?
  11. #25
    Mar 2011
    Quote Originally Posted by Romcik View Post
    If this santa fe is usa product and remote frequency is 315 mhz, it is very easy to program via OBD2 by,T300, SBB,X100,
    I do that daily,regards.
  12. #26
    Feb 2016
    SBB is - CK100.
    How to do it? On display ck100 turn ignition on, after that turn ignition off, after that displays ecu not found.
    Need remove key after that?
    Santa fe is europe.
    Thanks.
