Results 1 to 15 of 17
    garagetech's Avatar
    Oct 2008
    Default ford focus eeprom 95160 repair help
    please someone help i have ford focus 2005 1.6 tdci with ecu eprom fault :
    p1622 immobilizer id does not match
    p1603 eeprom malfuction /id number unregistered
    i mange to start car but now goes onto limp mode doesnt drive properly.i have read eeprom 95160 but when i compare its only 2k whilst others are 4k.
    please can someone repair my dump so the faults are fixed. if you need further info let me know
    thankyou
  2. The Following User Says Thank You to garagetech For This Useful Post:
    wojtech (27th June, 2014)
  3. #2
    WW
    how manage to start car ?, put here original eprom, flash from ecu (bdm read ) ,dump from dashboard
    garagetech's Avatar
    Oct 2008
    I used another dump from dk and initialised ecu with ids then started
    Im not sure how to read bdm ive got fgtech and bdm but never used them for bdm please help if u can, if the flash will do i can post that from 29f chip
    I will post original corrupted dump shortly
    The car is on site now, i only have ecu in my hand
    Thanks for reply
    i will upload flash shortly
    WW
    ecu dont have 29fxxx inside, put eprom original corupt here, dashboard dump, and if not succeed, flash dump
  6. The Following User Says Thank You to elephantul For This Useful Post:
    garagetech (24th November, 2013)
    Nov 2012
    smartville in front of a OBDplug
    no need of flash
    only eeprom content obd or bdm readed ..
  8. #6
    garagetech's Avatar
    Oct 2008
    Both eeprom is posted above first one posted start car but error no immo id second one no start thankyou
  9. #7
    WW
    Put this eprom in ecu, pass pm
  10. The Following 4 Users Say Thank You to elephantul For This Useful Post:
    euroscan1 (24th November, 2013), garagetech (24th November, 2013), radsky (27th June, 2014), wojtech (27th June, 2014)
  11. #8
    give me the ford serial number and I can found a good eprom for your ecu and then initialise with IDS. The problem is only in eeprom.
  12. The Following User Says Thank You to keysoftware For This Useful Post:
    elephantul (25th November, 2013)
  13. #9
    garagetech's Avatar
    Oct 2008
    Where shall i get this serial number from?
  14. #10
    from ECU label. I need it from original ECU to give you the exactly what you need.
  15. #11
    garagetech's Avatar
    Oct 2008
    Thanks please can you also add this immo id to the first dump if possible
    Cheers
  16. #12
    write this dump and pair with the IDS. Is from 4M51-12A650-NE ecu and I think is working for you. Have same 0281011263.
  17. The Following 3 Users Say Thank You to keysoftware For This Useful Post:
    2JZMk4 (13th May, 2021), Cdoc (27th February, 2014), garagetech (25th November, 2013)
  18. #13
    garagetech's Avatar
    Oct 2008
    Quote Originally Posted by keysoftware View Post
    Will try later
    car started with dump from elephantul had to initialise with ids, eprom error also gone but car in limp mode now , throttle reponse is very slow , car doesnt drive properly!!!
    help
  19. #14
    Aug 2015
    hello there did you manage to sort out your ecu fault I used mpps to turn off dpf now has screwed my ecu same as yours now im stuck ecu is bricked I have bdm100 flashing tool but need the file as mine does not start have ignition lights come on but nothing else would anyone be able to help me out thanks all
  20. #15
    Quote Originally Posted by garagetech View Post
    Will try later
    help
    WHENEVER you guys were given some help or suggestioin, please do report back to the forum, whether the solution works or not, rather than keeping silence on the issue...
