Results 1 to 13 of 13
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    Default Citroen C3 BSI - immo
    I have in my garage Citroen C3 2003-2004 year and he dont starter because BSI block are burned. (I don't know how first time see ).
    So i wanna to aske some questions:
    1- with what tool i can reprogram new BSI block to this car?
    2- When i connect to bosch in this car engine ecu i see faults but when i try clear to me say what can't I think engine ecu ar locked how need to do reset?
    3- From were i can find pin code? ,because i dont have car card.
    Thank you for answer.
    Apr 2012
    bullshit
    bay new BSI from car trash for same car same year same engine replace old eeprom on new bsi. car start
  3. The Following User Says Thank You to ivankurtev For This Useful Post:
    DjRomeoR (27th November, 2013)
    Nov 2011
    Garage...
    So I asking for help because i dont find from other same card BSI so i have only other BSI from partner car and wanna to reprogram to C3 and asking for help ,with what tool need to do this.
    AAND I SAY MY ENGINE ECU LOCKED
    Apr 2012
    I'm not sure about the compatibility BSI from partner
    search hard same car same engine
    tool
    Peugeot&Citroen Diagnostic Tool,Latest Diagbox,PP2000&Lexia 3.FedEx/DHL shipping | eBay
    example
    citroen bsi s118085300 I HG 9649811380 C2 C3 | eBay
  6. The Following User Says Thank You to ivankurtev For This Useful Post:
    Nov 2011
    Garage...
    Very thanks for help, i buyed lexia 3 , and i have BSI from partner and not other BSI.
    So i can now to do synchronization with engine ecu,BSI and keys?
  8. #6
    partner and C3 have not the same BSI
  9. The Following User Says Thank You to ammarben For This Useful Post:
  10. #7
    Nov 2011
    Garage...
    So i can only Citroen C3 BSI program to C3 ,and i f i have partner BSI i can't reprogram this BSI to Citroen C3 ? ((
    but one person from another forum say to me ,what to me need BSI and i can reprogram this BSI were i want , it is imposible ?
  11. #8
  12. The Following User Says Thank You to ammarben For This Useful Post:
  13. #9
    Nov 2011
    Garage...
    omg :/
    and with lexia 3 tool i can reprogram BSI from other car?
  14. #10
    Shmortz's Avatar
    in the middle of nowhere
    yes you can! I have replaced siemens BSI in partner using one from P206, many of the BSI's can be interchanged if they are one type... you just need to use VIN and PIN for your car and to reset used BSI before reuse it...
    ...this one you are searching is the same type I am talking about, I'm pretty shure that you can change it from peugeot to citroen, but you will know if you try it...
  15. The Following User Says Thank You to Shmortz For This Useful Post:
    DjRomeoR (28th November, 2013)
  16. #11
    Nov 2011
    Garage...
    Thank you for help.
    From were i can extract pin code ? i dont have car card with pin code.
  17. #12
    Apr 2012
    read eeprom inside BSI and post dump OR post VIN in http://www.digital-kaos.co.uk/forums...in-pin-286776/
  18. The Following User Says Thank You to ivankurtev For This Useful Post:
    DjRomeoR (29th November, 2013)
  19. #13
    Nov 2011
    Garage...
    Thank you all for help i resolved my problem.
