Results 1 to 12 of 12
    Default BMW Scanner 1.4 "factory defaults" function for cluster VIN change
    Attachment 233066
    Hello to all
    I received my used motometer gauge cluster earlier today. This is the same exact BMW part number as the one originally on the car
    I have tried to write the VIN with BMW Scanner but it requests to use the "factory defaults" and then write VIN but this option is greyed out and i cannot select it
    I had no problems setting the mileage to the exact kilometers as those registered on the light module but cannot write the vin.
    How can this be corrected?
    Mark
    I also tried coding data-recoding but it recodes the old vin and not my car's VIN
    Dec 2010
    Hmm
    I will take a look tomorrow
    Thank you
    Thank you so much!!!! That took care of the problem. I did the EWS-IKE and it set my cars information to the cluster. Then i added my vin number with bmw scanner as well!!!!
    Dec 2010
    [QUOTE=se93;2164868]Thank you so much!!!! That took care of the problem. I did the EWS-IKE and it set my cars information to the cluster. Then i added my vin number with bmw scanner as well!!!!
    How to wright vin with bmw scan?
    Can you explain
    thank you
    I entered into the EWS and selected the coding option EWS-IKE
    When i went back to the main screen i could see my ZCS information was written to the cluster
    Then i went into IKE-Programming- write FGSTNR and then entered the last 7 of my VIN and done. Tamper light gone and all is normal
    Dec 2010
    Why EWS not IKE
    are you sure?
    i have to do tomorrow the same job
    and wont to know exactly how to code
    new cluster and wright vin number.
    thank you
    Sent from my iPhone using Tapatalk[/QUOTE]
    EWS has the necessary information. That is what the thread you sent me indicated
    I did it and works perfectly. I used a donor cluster with the same exact part number and year of my car
    Also i noticed bmw scanner has a cluster part number compatible list and mine was there
  10. The Following User Says Thank You to se93 For This Useful Post:
    rukartinatv (4th December, 2013)
  11. #10
    Dec 2010
    Sorry but i read again post that i give you
    Look!!!
    you go with that v1.40 pa soft to "IKE"
    then to "coding"
    then you see "list" from "IKE - EWS" and some "EWS to IKE" and some more items.....
    choose the "ews to ike" menu (not the other)
    then it does automatic the coding
    done
    now you will see also ion "car identification" the info filed is not RED color anymore which means its now adapted to the car
    So instruction says go to ike then coding then ews-ike right?
    you say you went to ews module then coding
    then ews to ike?
    so how to do it right i have to enter in to ews or ike
    to code ews-ike?
    Thank you
    any one can help with this?
  12. #11
    Here is what i did
    I opened up bmw scanner software
    Then i went into EWS and selected EWS-IKE
    I then went to the main screen where the vehicle IKE/EWS data is and the ZCS was that of my car and the 328ci chassis code too
    Then i went into IKE-Programming-write FGSTNR and entered the last 7 of my vin and it started to process and done. When i looked at the upper right hand corner of the bmw scanner software i saw MY VIN!!!!!!!!
  13. The Following User Says Thank You to se93 For This Useful Post:
  14. #12
    Here is the correct sequence:
    EWS-Reprogramming-Copy ZCS/FA coding
    Then you will see
    IKE to EWS
    EWS to IKE
    Select EWS to IKE
    After i did this, i went to
    IKE-Reprogramming-Write FGSTNR
    Then i entered the last 7 of my vin and it was done
    Hope this is much clearer for you
    Mark
  15. The Following User Says Thank You to se93 For This Useful Post:
