Results 1 to 13 of 13
    Dec 2013
    Unhappy Citroen C5 2.0 16v 2002 "Airbag fault"
    I've got a "small" problem with my airbag system. When i turn-on ignition display shows me "Airbag fault". I plugged my lexia, and airbag computer showed one fault. I've got lexia in Polish and i can't translate it perfect, but it was something like "calculator Configuration fault", fault code P2041. I checked, that 6 bags are in car and computer is configurated for 6 bags too. Battery disconnecting doesn't change anything. I don't have any ideas, how can i solve this. Do you have any ideas?
    It's TEMIC 9648403180
    Thanks in advance
    BAILE ATHA CLIATH
    Check for broken wire between passenger headlamp and fusebox
    Dec 2013
    Quote Originally Posted by scoot View Post
    I switched language in interface and now fault sounds "ECU configutation fault, not specified" and fault code is P1041 - i was wrong in last post.
    Scoot,
    Could you describe me, when this wire is? What means "passenger headlamp"? Are you thinking about lamp, which is placed above front window? Do you have pinout for my airbag ECU?
    Thanks for your reply
    Jul 2013
    yorkshire
    Originally Posted by scoot Check for broken wire between passenger headlamp and fusebox. I think this should read "behind passenger headlamp" as the loom runs behind the left headlamp. Has the car ever been in a crash? If yes, you have to get the crash data removed from srs module.
    autoden.
    Dec 2013
    I'm not sure, that car have ever been in crash. I hope no, but everything is possible.
    Ok, i will check this loom if i will find some free time.
    Crash data? I don't think so, because this fault appeared unexpactedly.
    Thanks for advices, guys because each advice is very important.
    BAILE ATHA CLIATH
    Yes sorry for not being specific as far as i remember its the loom coming from fusebox on passenger side and goesdown behind headlamp pull the wires gently as they can be broken internally
    Dec 2013
    I checked this loom, but the problem does not disappeared...I looking for pinout of Temic ECU. I used google, but i can't find. It's the same for each Temic, or different? I found ECU, but the identification numbers are not the same. I suppose, that problem is in ecu, but i'm not sure and i don't have tools to check it.
    Dec 2013
    Can someone help me? Still need pinout for Temic. I supposed, that fault is in ECU software, because i checked all wires. What should i do after ECU replace? It will be enough, if I set correct airbags with Lexia? Whick Temic ECU will be proper?(which numbers, marks have to be the same)?
    Dec 2013
    Sorry for two posts together, but i tried to delete previous and i didn't find button.
    I disassembled airbag ECU yesterday, and i've been in shock. I have soldered 3 resistors inside ECU - in circuit responsible for lateral airbag, passenger pretensioner and air curtain (you know what i mean, sometimes i use translator ). I supposed i solve this problem, because i found a jumper?(short wire soldered between two points). I guess, it was soldered same years ago and due to time it is cracked. Main problem is, where this wire should be soldered? It is a standard procedure after crash (resistor and jumper) or should i try to find any broken paths on PCB?
    See below: (sorry for photo quality)
    Meat-Head's Avatar
    Err best throw that away and get another before you hurt yourself or a non forum member
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    P1041 is usually caused by faulty steering wheel squib connector,in other words,check steering wheel airbag connection,and whatever you did,unsolder everything from airbag ecu,and return all to factory state,before someone gets hurt!!!
    Meat-Head's Avatar
    Wicked video on youtuba
    bloke sat on tires on an airbag, goes bang, he wacks his head. HARD on the ceiling and goes off line for a few mins, could have broke his neck and paralysed him, or permantly killed him
  13. #13
    Dec 2013
    Thenks for all advices Problem was solved, airbags with pretensioners were replaced and the system working very well after ECU replacement.
    Regards,
    Jack
