Results 1 to 2 of 2
    Dec 2013
    USA
    Default MB STAR C4 SD CONNECT HELP
    Hey! I recently purchased a mb star c4 sd connect and installed everything when I connect the star c4 sd connect I can't seem to click on the work cable connection ( autom selection) under multiplexer. I am thinking if the green cable which is the lan cable is bad or if I am doing something wrong. I also deleted the configuration on the star c4 sd connect to start fresh. I tried a regular ethernet cable with no luck. Any help would be appreciated thanks
    Nov 2013
    Texas, US
    Do you have Compact4 and NOT Compact2 in your registry? Can you post screenshots?
