Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    Spain
    Default IMMO OFF TATA INDICA 1.4
    Hello friends.
    I need your help.
    I've a ecu of Tata Indica 1.4 and i need immo off.
    The problem is i lost the 95080 and i haven't ori dump.
    Can someone upload a ori dump o immo off dump.
    The ecu is similar to sagem2000 peugeot-citroen.
    Thanks!!!
    keygargoil's Avatar
    not many will have what your asking for how did you lose it
    I think youl need to buy a new ecu from scrapyard o dealer pal
    daniersms's Avatar
    South Africa
    I think this Tata uses a remote with the immo box beneath the front seat and if so you can just bridge a couple of wires and it will work
    Love this forum
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by hector View Post
    Hello friends.
    I need your help.
    Thanks!!!
    If it is EDC15C2 you could try this file.
    Will sent you pass soon.
    Livingstone
    Do not use the eeprom file I downloaded your car is not edc15. This is Indian tata car.
    Spain
    How can i bridge a couple of wires. can you explain me?
    daniersms's Avatar
    South Africa
    Just confirm first if there is a box and maybe some relays beneath the seat and I will prepare you a how to
    Love this forum
  8. The Following User Says Thank You to daniersms For This Useful Post:
    hector (24th December, 2013)
    Spain
    Hello daniersms. the car has the box and relays under seat.
  10. #9
    daniersms's Avatar
    South Africa
    Ok unplug both plugs from immo box.On the small plug bridge the 2 y/red wires then the thin black bridge to thick black for earth and give ignition to red/blue for the fuel pump.there should be 2 red/blue wires but check the one for the fuel pump-----Car should start if ecu is ok ---Good luck
    Love this forum
  11. The Following 7 Users Say Thank You to daniersms For This Useful Post:
    BigJ (28th September, 2018), hector (24th December, 2013), KennySmit (15th June, 2014), mancinofranco (25th April, 2015), marcobh5 (19th February, 2016), pinotec (28th February, 2014), tmkz (11th July, 2017)
  12. #10
    Spain
    Ok, but i have a big problem, je je je. I removed the eprom 95080 from ECu, with such bad luck that I lost the eprom.
    I can not find it anywhere.
    Do you have the orignal dump?
    Anyway i'll do it.
    I'll keep you informed.
  13. #11
    Spain
    Hello, i've a problem.
    The color code no is equal.
    I upload a photo with the small plug, and colors.
  14. The Following 3 Users Say Thank You to hector For This Useful Post:
    DOUGLASDL (19th April, 2017), mustafa06 (29th August, 2016), pinotec (28th February, 2014)
  15. #12
    Jul 2011
    give me full detail of car which model is this and which year all deatil
  16. #13
    Jul 2011
    forr pass. pm
    this is immo off
  17. The Following 8 Users Say Thank You to raj03 For This Useful Post:
    antonypaul (9th May, 2014), dvdpgn (20th March, 2016), KennySmit (15th June, 2014), mancinofranco (25th April, 2015), mustafa06 (29th August, 2016), pinotec (28th February, 2014), sfmaldo (18th October, 2018), thaeerkh (31st August, 2018)
  18. #14
    Spain
    Hello friends. Finally the car starts!!!!
    Soon I'll post the solution.
    Thanks to all
  19. The Following 4 Users Say Thank You to hector For This Useful Post:
    antonypaul (9th May, 2014), ecumix (12th April, 2022), mancinofranco (27th April, 2015), pinotec (28th February, 2014)
  20. #15
    hi hector
    is possible to obtain the solution or the wiring diagram for immo off ?
    I understand that the color of the connector varies depending on the country of manufacture of the car?
