Results 1 to 10 of 10
    Top Poster + ross79ta's Avatar
    Italy
    Default EEProm Hex Editor
    Hello, i see this product: EEProm Hex Editor - MTX Electronics.
    I translate description:
    This software is an hex editor specifically developed to work on EEprom (E2P) engine control units. The user interface is optimized to work with both the original file and the edited one at the same time allows the synchronization of the two files on the movement. For EDC16 the checksum is calculated automatically when you save the file.
    Some features:
    - Displays both the original and modified files;
    - Synchronizes files between shifts;
    - Highlights the areas of files that have changed;
    - Separate bookmark for both files;
    - Calculate the checksum automatically (only EDC16);
    - Highlights the areas not covered by the checksum of the file.
    I'd like to have suggestion, because i'd want to buy it... what do you think about it? It seems an interesting sw, because it's useful with immo off or mileage on ecu...
    Jun 2013
    EU
    It would be interesting if it offer a map of the eeprom fields, raw editting i think can be done with any hex editor.
    Don't know price but only for checksum correction...
    Regards,
    Italy
    price is in linked webpage: 183,00 €
    Not so much expensive.
    Babos's Avatar
    Mar 2012
    for what is this need?
    take free hex editor or ols mod eeprom and after calculate with free sw who can do this!
    If you not have expireance that can be expensive.
    Best regards.
    Dec 2012
    to compare the contents of files, you can use the normal total Commander and costs nothing
    Italy
    Quote Originally Posted by robert02500 View Post
    Yes, but that sw can calculate cks on eeprom of EVERY EDC16, not only for Vw.
    Italy
    Quote Originally Posted by Babos View Post
    Best regards.
    With which sw free you can calculate cks on eeprom of ALL EDC16?
    Babos's Avatar
    Mar 2012
    Quote Originally Posted by ross79ta View Post
    not for all but 40% brands.
    other 60% can do via other metodic
    i write before this all is expireance
    Nov 2012
    smartville in front of a OBDplug
    my edc16 eeprom are automatically checksumed in winols with a a special plugin
    Italy
    Quote Originally Posted by kennfeld View Post
    but you have winols original?
