Results 1 to 9 of 9
    Jan 2014
    Default an error has occurred, please eject the disc?(usb loader gx problem)
    Hello everyone. I've been trying to get usb loader gx to load games from my usb hdd for the last couple of days, but I just can't seem to get it working. I've read several threads here and tried installing wad packs, apps and cIOS versions before posting a new thread. But I still can't seem to get it working. usb loader gx sees the games and I even see a little preview before loading them. But when I load them, the screen goes black and I get the error "an error has occurred please eject the disc...". I have a partioned western digital passport of 2TB. one is ntfs and another fat32. I tried with both partitions, same problem. If anyone can help me out, that would be great. Thanks!
    Here's a system check:
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Could not detect the drive date!
    Homebrew Channel 1.1.0 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 78830000
    Boot2 v4
    Found 75 titles.
    Found 55 IOS on this console. 5 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: Hermes-v55.1): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 65535, Info: Hermes-v55.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[37] (rev 65535, Info: Hermes-v55.1): Trucha Bug, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: Hermes-v55.1): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2014/01/05.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Welcome to DK.
    There is nothing wrong with that sysCheck its your 2TB passport drive that's the problem, they use too much power spin them up than the USB port can provide.
    You need a 1TB mains powered HDD that will hold about 500 games.
    All the new USB Loader will use FA32, NTFS and WBFS formatted drives.
    Keith
    2010 Golf GTD (170)
  3. The Following User Says Thank You to Keithuk For This Useful Post:
    isnie (6th January, 2014)
    Jan 2014
    Thank you for the suggestion. I'll try with another drive and report back.
    Aug 2010
    England
    Well a quick way is use the biggest USB flash drive you have.
    You should get 2 games on a 2GB drive (formatted FAT32 or NTFS) providing you add them with Wii Game Manager because it adds games as WBFS files which are a quarter of the size of an iso file.
    If they play then its the drive.
    Keith
    2010 Golf GTD (170)
    Jan 2014
    Quote Originally Posted by Keithuk View Post
    I just tried using a 8gb flash drive formated as wbfs and transfered the iso with "Witgui"(I'm on mac) to the drive, but I encountered the same problem. I also tried with a main powered one that is formated as ntfs, where I created a folder wbfs and placed the wbfs files in the folder. that didn't work either. the main powered drive should be supported by usb loader since it's in the list and I also see a preview of the game before I start it. I've also tried formatting the usb drive as fat32 and placing a wbfs file in a wbfs folder. also the same problem. I had another 32gb flash drive but usb loader didn't recognise it. Am I missing some kind of setting? Or did something go wrong with the cIOS files?
    DK Veteran bowie's Avatar
    May 2009
    God's country
    you could try using wbfs manager. format the drive using this, then add the games. this has always worked well for me
    Men of Harlech onto glory
    This shall ever be your story
    Keep these fighting words before ye
    Cambria will not yield
    Aug 2010
    England
    isne I don't know your system without a seeing a sysCheck19 report to see what you've installed.
    I've always used WBFS Manager and its never failed.
    Keith
    2010 Golf GTD (170)
    Jan 2014
    I'm gonna find a pc and see if using wbfs manager will work and report back.
    below you can find the report.
    Region: PAL
    Hollywood v0x11
    Boot2 v4
    Found 75 titles.
    BC v6
    MIOS v10
    Report generated on 2014/01/09.
    and the log
    IOS9 get_ios_base:
    7c 7a 60 f, e4 85 77 89, 64 5a a1 a0, be a3 4d 59, 83 68 75 a6
    IOS11 get_ios_base:
    36 2a 6a 4f, 78 72 e3 18, 7d d1 b1 f6, fa 1f f1 a6, 80 ec ee c9
    IOS12 get_ios_base:
    ba bf a4 78, da 4e 6 ec, f0 53 1a f0, 7f ad e2 eb, ff 3f cb 5d
    IOS13 get_ios_base:
    5e a2 9d 72, 7e 56 37 26, 3f 62 3d 78, 1c 3 d2 f3, f5 40 52 5c
    IOS14 get_ios_base:
    3d 56 e 38, ce 93 90 4f, 42 b7 8f e9, b7 86 f1 a8, f9 39 b6 ce
    IOS15 get_ios_base:
    74 7c e3 33, 83 94 97 d7, a2 86 67 47, 55 61 83 a, d0 3c 60 48
    IOS17 get_ios_base:
    77 7b 4c cb, 9a fb fe fc, 20 ee 4c e, 58 a1 6b ff, a0 20 a2 23
    IOS20 get_ios_base:
    IOS21 get_ios_base:
    91 ba e4 26, 1b 49 f0 95, e0 8c 21 17, e1 fa 8b e9, 92 6d eb 1b
    IOS22 get_ios_base:
    8d 84 49 8b, f5 ba 6c a8, f0 58 64 10, 40 25 cd 1c, 25 9b 8a f6
    IOS28 get_ios_base:
    5c cd 8 24, 19 7b 9a 2, 17 55 5d f9, 39 dc dc 49, 73 ea 75 6a
    IOS30 get_ios_base:
    IOS31 get_ios_base:
    71 5f d8 87, 67 3e 32 4c, 53 c5 0 ce, 2b 50 14 f7, f2 ff e8 31
    IOS33 get_ios_base:
    fc cf c4 1b, fc 8c 12 9e, 1f 67 5b 42, d4 3d 10 d6, 56 4f f5 f9
    IOS34 get_ios_base:
    68 8a 19 ae, c4 9f 57 fb, 11 1b 31 49, 2b 4d b4 85, 25 a6 3f 72
    IOS35 get_ios_base:
    58 5e 4 25, 45 d4 e2 8e, 98 fe d cd, 76 d0 71 d6, ac 17 a0 9c
    IOS36 get_ios_base:
    aa 95 a1 ac, 9c 43 f8 ca, af 50 41 fc, 3 7d 8b 4a, 5d 20 8e 25
    IOS37 get_ios_base:
    32 c7 bc 54, 92 f6 17 e2, 64 26 e3 ce, bd 36 9f 40, 42 ea e8 2
    IOS38 get_ios_base:
    f5 77 6b 66, cd 74 12 ee, 19 12 5c 11, 54 bf d7 3e, d7 e4 af 4b
    IOS40 get_ios_base:
    IOS41 get_ios_base:
    6c ad 7f 85, b6 87 e3 c3, 17 4e 5c 79, 99 fd 1 83, 16 55 fa 6f
    IOS43 get_ios_base:
    f8 46 be 2, 74 e7 90 a3, d9 0 9a ae, d5 95 3f 77, e3 3f ad 2a
    IOS45 get_ios_base:
    8 58 11 20, 6b 3a e5 9f, b9 10 16 8b, 8a ea 6 3d, 9c 14 80 ef
    IOS46 get_ios_base:
    f5 e0 93 27, 26 cb 68 7b, ac e7 cc 86, 39 77 71 d1, ba 9e 42 36
    IOS48 get_ios_base:
    8d 53 7a 4a, 9 51 e5 6b, 2b 65 c8 27, f0 47 bb 72, c3 5c da e2
    IOS50 get_ios_base:
    IOS52 get_ios_base:
    IOS53 get_ios_base:
    78 68 c0 50, 5c d6 d5 15, 65 d7 d8 f, f0 a2 d9 d4, 9e 1d 7d fb
    IOS55 get_ios_base:
    c5 0 19 41, 22 18 21 92, b6 39 c9 d2, 5 fe 3f b3, 43 36 ae c
    IOS56 get_ios_base:
    1b cc cf 7, f1 c d5 12, be 96 9a a5, d2 36 67 98, 30 71 e6 81
    IOS57 get_ios_base:
    e7 46 7 56, 4c e8 69 2f, cd e1 19 2, 26 d6 a1 dd, 82 4c ef c
    IOS58 get_ios_base:
    aa 1 bd 67, 7c 20 dc 28, 9c c6 b0 c9, 48 4b d3 f7, cd bc 4b 10
    IOS60 get_ios_base:
    IOS61 get_ios_base:
    95 f2 cb 4c, e8 d3 d3 76, 45 66 56 40, 35 db cd 7d, cd 99 24 24
    IOS62 get_ios_base:
    1d 7f 81 d5, de 4a 2d ca, 76 56 97 3e, 49 ed a4 17, 89 42 33 5f
    IOS70 get_ios_base:
    IOS80 get_ios_base:
    IOS236 get_ios_base:
    2f d8 8e 4b, d4 7f a8 f1, 1b d3 9d 7e, 79 f8 8f 9d, d1 ab 19 d8
    IOS256 get_ios_base:
    9b dd e2 3c, cd 56 a0 ca, d7 ca fd ce, 51 a3 40 d2, 13 42 9a a4
    IOS257 get_ios_base:
    a7 15 9d 1c, 70 18 96 e4, cd 7c da 3, 6 d6 c2 ba, 24 4 11 c1
  10. #9
    Jan 2014
    well I also tried using wbfs manager on a pc and I got the same issue. maybe i should retry uninstalling and installing everything again. is there any good guide I can use? There are so many that I don't know which one is a good one.
