Results 1 to 15 of 18
    Garage
    Default IMMO OFF Safir 1 35 Pin
    Hi all friends, i need to to immo off on SAFIR 1 35 pin, attention SAFIR1 with 35 pin $T2eC16J,!)gFIb!jYJNdBSPdmU5M0!~~60_12.JPG
    i tested decode with renault decode tool (click click) i do exactly shema on PDF, after 4 hours click click, led is green...
    i do test on table, alimentation on ecu, look MIL bulb, ignition ON, MIL light, after 2 seconds, OFF
    IMMO is OFF?
    i cut pin 30, test on car, don't start and MIL blink... :-(
    return to home, open ecu, cut rubber, solder wire pin 22 (27c512), alimentation on ecu, touch pin 22 27c512 x10 to negative and tested pin 23 to negative too (lesson click click on relay)
    when i test on table, always same result, MIL no flash, just light 2 seconds, after is OFF, i lesson relay click and after 1 second, click again...
    Do you think immo off is OK?
    Or need absolutly connect ecu to car to do pin 22 to ground manipulation (can't do on table with power supply?)
    Thanks to all.
    Lobster247's Avatar
    Sep 2012
    Belarus. Grodno
    What your car and engine?
  3. The Following User Says Thank You to Lobster247 For This Useful Post:
    elcarpuz (6th January, 2014)
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Find correct immo pin on ecu, repeat procedure with ground on pin 22, but put it on car with removed immo line and test.
    Here to HELP!
  5. The Following User Says Thank You to immokill For This Useful Post:
  6. #4
    Garage
    it's on clio 1996, i thinkl correct immo pin is 30
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Is there one or two wires on pin 30?
    Here to HELP!
  8. The Following User Says Thank You to immokill For This Useful Post:
  9. #6
    Garage
    Just one wire on pin 30
  10. #7
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Ok,then try method on car it should work .
    Here to HELP!
  11. #8
    Garage
    If pin 30 cut, on car or on table, is same result no?
    i haveńt the car here
  12. #9
    jakkeviet's Avatar
    Apr 2012
    hi
    which engine it is ??? 1.8 pin 30 is lambda sensor and pin 29 is immo color VI/SW
    1.2 and 1.4 engine pin 30 is idle whitout immo
    could you tell me what engine it is
  13. #10
    Garage
    I restest renault decoder this night, when finish all led are OFF :-(
  14. #11
    Garage
    Ok i look for engine type, but, with 27c512 pin 22 to ground, after relay is always actived? Because i lesson active click and after 1 or 2 seconds, click , immo is not off?
  15. #12
    Jul 2013
    Lublin
  16. #13
    Garage
    Same tool but not same version
  17. #14
    Jul 2013
    Lublin
    Ok i will try to help .
    So.....
    PIN 4 AND 34 TOGETHER THEN TO BLACK CABLE IN DECODER AND TO GROUND
    RED CABLE FROM DECODER TO 12V
    PIN 30 TO GREEN CABLE FROM DECODER
    FROM PIN 20 ECU TO PIN 85 RELAY ( GROUND )
    FROM PIN 18 ECU TO PIN 86 RELAY ( + 12V ) AND CONECT YELLOW CABLE FROM DECODER TO THE SAME PIN RELAY AND PLEASE CONECT THE ( LIGHT/BULB ) 12V TO THE SAME PIN RELAY (86)
    GROUND FROM THE LIGHT PLEASE CONNECT TO PIN 19 ECU
    NOW BEFORE YOU START !
    PLEASE CONNECT RED CABLE 12V WITH YELLOW! IF YOUR CONNECTION IS GOOD THE LIGHT SHOULD FLASH FOR ONE MOMENT AND THEN BLINKING
    AFTER PLEASE DISCONECT RED CABLE FROM YELLOW AND CHOSE ADVANCED 1 FOR SAFIR 1 AND 2
    AFTER 4 HOURS WHEN DECODER SWITCH OFF PLEASE CHECK IF YOU ARE TOOK IMMO FROM ECU
    PLEASE CONNECT AGAIN RED WITH YELLOW --- IF ECU ARE DECODED THEN THE LIGHT FLASH FOR ABOUT 5SEK AND THEN GONE OR WILL BE FLASHING AL THE TIME
    IF LIGHTS WILL BE BLINKING THATS MEANS YOUR ECU STILL HAVE IMMO
    Please let me know
  18. The Following User Says Thank You to marlborored For This Useful Post:
    elcarpuz (7th January, 2014)
  19. #15
    Garage
    I test exaclty your connection and when yellow with red wire, light flash for 3 or 4 second and after no flash no blink...
    i can lesson relay TIC when i connect red and yellow wire, i look light flash 3 or 4 second and lesson again TIC relay, and light is off forever...
    Immo disable?
