    electrones's Avatar
    Feb 2012
    Around C.V
    Unhappy I need help to remove dtc from siemens sid 801, please!!
    Hi friends
    I have this peugeot 307 2.0 hdi 90 hp, siemens sid 801, year 2002,
    i tried to make immo off but without sucess, after several attempts, i have this DTC and not clear by diag interface
    DTC:
    P1520
    P1403
    P1404
    P0603
    P1613
    Some one can help to fix please!!
    Thanks in advance
    Cheers
    Press "THANKS" button. just one click, CHEERS
    electrones's Avatar
    Feb 2012
    Around C.V
    Any help please!!
    May 2013
    test? et approuv? sur un ecu sid801A de 307 2.0 HDI 90
    CAUTION must read and write eeprom 93C56 16-bit
  4. The Following User Says Thank You to dell66 For This Useful Post:
    electrones (10th January, 2014)
    May 2013
    the car starts without gradient mode, or default code
    pass pls thanks
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by dell66 View Post
    Thank you m8
    CAr doesn't start, ecu show locked
    Cheers
