Results 1 to 8 of 8
    V.I.P. Member Herbie's Avatar
    Mar 2008
    Default SSBB Working without Dual channels or 15% trick
    I don?t take any credit for this information, this is just a "Copy and Paste" from different post around the net.
    All the credit should go to the original posters.
    1. Download Trucha Signer 0.21 http://www.ingenieria-inversa.cl/files/trucha021.rar
    2. Download RegionFrii 1.21 http://gbatemp.net/index.php?download=722
    3. Download Ultraedit http://www.ultraedit.com/
    4. Unzip everything and put them into a central directory.
    5. Open up the "wiikeyset.reg" that came with the Trucha Signer in UltraEdit and find the section:
    [HKEY_CURRENT_USER\Software\Wii\KeySet\2]
    "name"="Custom KeySet 1"
    "boot1 key"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00 ,00,00
    "common key"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00 ,00,00
    "sd key"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00 ,00,00
    "sd iv"=hex:00,00,00,00,00,00,00,00,00,00,00,00,00,00, 00,00
    "md5 blanker"=hex:00,00,00,00,00,00,00,00,00,00,00,00,0 0,00,00,00
    6. Open the key.bin file in UltraEdit and make sure you are in hex mode (Ctrl-H).
    * key.bin (You need to find it and download it for yourself, can?t link to this file)
    Google it! It will have an MD5 of 8D1A2EBCD82A3469B77FACF15D9C8E50
    7. Replace the "common key" line...
    ...with the contents from key.bin. For example, if key.bin contained AABBCCDDEEFFAABBCCDDEEFF11223344, you'd enter...
    "common key"=hex:AA,BB,CC,DD,EE,FF,AA,BB,CC,DD,EE,FF,11,22 ,33,44
    8. Save the "wiikeyset.reg" file and activate it by double clicking on it. Click "Yes" to add it to the registry.
    9. Start Trucha Signer and Select KeySet->Custom KeySet 1
    10. Click Image->Open ISO and load SSBB ISO
    11. Expand DISC->PARITION (RELSAB)->ROOT
    12. Right click __update.inf and select extract to file (save it to your desktop and then delete the file)
    13. Download Prophets modified __update.inf http://www.filefactory.com/file/6672f5
    14. Right click __update.inf in Trucha and select Replace and browse for Prophets ProphSSBB.inf
    15. Right click PARTITION (RELSAB) and select Trucha Sign It! (do the same to PARTITION (RSBE01) just to be sure)
    16. Close Trucha and start Regionfrii.
    17. Load the SSBB Iso and select New Region->PAL (Default) and click Update ISO
    18. Download and install ImgBurn http://www.imgburn.com/index.php?act=download
    19. Start up ImgBurn and go to Tools->Settings...->Write->Layer Break->User Specified and enter 2084960
    20. Burn the game to a DVD+R DL
    21. Insert the game to your Wii and if it asks to update let it update 100%
    22. Enjoy Brawl on your PAL Wii without dual channels
    Thank you all that posted all this information and I hope you don?t mind that I collected it all in one post.
    Hope this will help a lot of confused ppl
    EDIT: Forgot to mention my setup: PAL Wii 3.2E with D2CKEY (But it should work on all modchips)
    I did not need to do this part myself
    Additional info for some users:
    Remove the 001 Error:
    Do this between step 14 and 15.
    1. Go into the second partition PARTITION (RSBE01), extract the main.dol
    2. Load the main.dol with the bailli tool and hit " remove 001. then hit SAVE. if you do not hit save, it wont fix it.
    3. In trucha signer, right click the main.dol that you just extracted and hit replace
    4. Right click the partition in trucha signer and resign the partition
    Change the Video Mode to support 480p/480i/576i
    If you are patching for "Remove the 001 Error" do this after step 2 on the same main.dol file that you have already patched with baillis tool.
    2. Load the main.dol with the Wii Video Mode Changer 2.2 http://rapidshare.com/files/98050614/wii-vmc_2.2.zip
    3. Select Smart Mode, NTSC->PAL
    4. In trucha signer, right click the main.dol that you just extracted and hit replace
    5. Right click the partition in trucha signer and resign the partition
    Mar 2008
    I can confirm this works with a yosam chip not sure what firmware need to check with wiiman burnt to RITEK-S04-66 DVD+R DL accepted the update game works flawlessly with no double channels
    Top Poster PAUL7331's Avatar
    Mar 2008
    Wii man, will this work with that new chip you gave me? (chip that runs Mario Galaxy) or will I need to do all of the above first?
    V.I.P. Member wiiman's Avatar
    Mar 2008
    Quote Originally Posted by Herbie View Post
    I belive your yaosm was either 1.9 or 2.0 herbie.
    Mar 2008
    Quote Originally Posted by PAUL7331 View Post
    As long as you take the step to remove the error 001 then this will work fine on your wii mate.
    Mar 2008
    Default PPF patch
    This PPF patch will modify the WiiZARD's iso file so the game
    can be played on PAL Wii systems. We removed the english updates
    so it doesn't apply the updates and you won't get duplicate
    channels. The region of the wii game is also patched. The modchip
    doesn't have to change the region on the fly anymore. This patch
    is confirmed working on the Wiikey 1.9g firmware in combination
    with 3.2E. The game runs on 60Hz and without any framedrops.
    It's signed with the Trucha Signer.
    How to install:
    1. Extract the WiiZARD release to a folder.
    2. Extract the included rar file to the same folder.
    3. Start "ppf-o-matic3.exe"
    4. Select the ISO File, WiiZARD's iso.
    5. Select the included Patch file, our ppf patch.
    6. Press apply, and wait for the finished sign.
    7. Leech ImageBurn, http://www.imgburn.com/
    8. Select write image to disc, select the iso file (source).
    9. Set write speed to 2.4x, just to be safe.
    10. Burn the baby.
    11. Alternatively you can add the layer break manually, this
    didn't work for me, but for some others. Here is how it goes:
    In ImageBurn click Tools->Settings->Write Tab
    In the options section select Layer Break "User specified"
    and enter the following number: 2084960. Press OK and BURN.
    Have fun gaming this nice dual layer wii-game...
    Thanks for the patch m8!
    Does any have download wii games without mod chip links?
    I don't know hot to download wii games without mod chip .
    Pls help me. THanks.
