Results 1 to 8 of 8
    Jan 2014
    Default Wii won't detect USB drive
    So I used ModMii to mod my Wii last night, and no matter what, I can't seem to get it to detect my USB drive. Using the channel installed by ModMii, it simply displays "Please insert USB drive" (or something to that effect). With USB Loader GX, it hangs on "initializing USB device". Any ideas?
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Drive date: 2006.09.07
    Homebrew Channel 1.1.2 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 36959617
    Boot2 v4
    Found 99 titles.
    Found 49 IOS on this console. 5 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65280): Stub
    BC v6
    MIOS v10
    Report generated on 2014/01/13.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Welcome to DK.
    That sysCheck looks ok apart from ModMii only installs 2 d2 v8.0 wads you need to install all 7 from d2x v8 Final wad pack
    What type of drive are you using and how is it formatted as incompatible drives is the biggest problem?
    Keith
    2010 Golf GTD (170)
    Jan 2014
    I've installed the d2x v8 wad pack, but it looks like I'm still having the same issue: USB Loader GX freezes on "Initialize usb device", requiring a manual reset, and the USB channel installed by ModMii just says "Please connect a USB drive". I'm using a SanDisk Cruzer Switch 8GB. According to the USB Compatibility List, SanDisk flash drives work consistently across the board. The flash drive is formatted as FAT32, and has a WBFS folder with a .wbfs game in it.
    Aug 2010
    England
    Well I don't know where you had USB Loader GX from but ModMii doesn't supply that only CFG USB Loader and Wiiflow I assume your using USB Loader GX 3.0?
    I've said many times USB flash drives aren't worth using as the capacity is to small for games your better of using a mains powered USB drive.
    Keith
    2010 Golf GTD (170)
    Jan 2014
    I loaded USB Loader GX 3.0 just to confirm that it, too, didn't detect the USB drive (in addition to CFG USB Loader). And while I understand a flash drive isn't the most optimal, it is the only thing I have available. Mains-powered USB drives are hard to come by.
    Aug 2010
    England
    You are using the correct USB port the one nearest the edge of the Wii as the other one doesn't work for drives. Actually if Wiiflow can't find the drive it shows you a picture of which USB port to use.
    12 months ago I thought I would try a 4GB flash drive to see if it would play games. I used Wii Game Manager to add 4 wbfs games to the wbfs folder and all games worked.
    Mains powered USB external hard drives are available just Google them or search fleabay.
    Keith
    2010 Golf GTD (170)
    Jan 2014
    Quote Originally Posted by Keithuk View Post
    i am habving the same problem
    Aug 2010
    England
    Yes so what's you conclusion what you've read on here?
    Keith
    2010 Golf GTD (170)
