Results 1 to 8 of 8
    Northern europe
    Default Ford Mondeo 2008 Visteon Dash Pinout ? 32 Pin connector
    Hello.
    Does anyone have a pinout for the visteon dash 32 pin connector from Ford Mondeo / Galaxy 2008 ?
    I am trying to test on the bench and according to some post found here Pin 2 should be Ground and Pin 32 should be 12V+ but I think I am missing a ground or something ??
    First time connected like this it started up and I could see the dash display but now it will only flicker a few times like a loose connection somewhere and will stop.
    I can also see the amperage fluctuating a few times and then nothing.
    Maybe a diagram ?
    Much appreciated.
  2. The Following User Says Thank You to jaxone For This Useful Post:
    joesmondeo (16th August, 2023)
  3. #2
    Nov 2011
    Macedonia
    Default i have this
    i have only this
  4. The Following 2 Users Say Thank You to baze007 For This Useful Post:
    jaxone (24th January, 2014), vavrich (17th April, 2019)
  5. #3
    Northern europe
    Thanks, this is what I have also.
    I just tried to BEND the board a little and it starts !!
    So it's an imperfect contact / soldering somewhere or the circuit is broken somewhere.
    Any ideas how can I find this without a diagram ?
  6. #4
    Nov 2011
    Macedonia
    Much more difficult to do without a diagram ...... for this job you will need time and a lot of work
    Good luck
    Northern europe
    I went with hot gun over all components and connections and it's working now.
    Thanks for the help.
  8. #6
    Aug 2018
    Hello There!
    I have a same problem with a Galaxy dashboard. 8M2T-10849-RA
    I tried to power up, it works, but when I move or bend the panel, the dash stopped to work. I tried to re-solder all of the connector pins, but it is not help.
    I think it is a crack somewhere the middle part of the panel ( I bent here when I reproduce the problem) , I check the parts visually, but I can not find the problem.
    Have you got any idea which part is cracked?
    Thanks in advance!
  9. #7
    Nov 2023
    Hungary
    I have same issue with Modeo MK4 2008 Dashboard.
    Earlier: LCD sometimes OFF, sometimes work well, sometimes mixed the pixels.
    Now: LCD 50% - OFF.
    Action: Resoldered of the main connector and the one of the LCD connector which side is not working well. But I do not know how looks like the real connection with the electrical panel.
    Can you advice how can I fix the problem? Maybe the other side of the LCD connector resoldering also necessary?
    Is there any component which is need to change to solve the fault?
    I tried to find wiring diagram data but I could not.
    Can somebody put here some drw or photo or wiring diagram data only for dash?
  10. #8
    Re-solder the Prozessor...
