Results 1 to 8 of 8
    Oct 2010
    EU
    Default A-Class (168) 1.4 MSM1.1
    Can anybody help with this Start error:
    A140 1.4 60kW
    ECU: MSM1.1 a026 545 05 32 (4) (with flash 20f200)
    Immobox: Siemens 1688200426 5wk4736 (with Motorola 0D69J = HC05x32)
    In display is "Start error", starter not spin, in ECU is fault code "P0600-CAN from FBS (CAN from immobox)"
    Please, can anybody help?
    Many thanks in advance.
    pepi's Avatar
    Check wires from FSB to ECU.
    Oct 2010
    EU
    Thanks, but wires are ok.
    Top Poster AutoElectronicaFS's Avatar
    Apr 2014
    Rafaela, Santa Fe, Argentina
    Quote Originally Posted by Pali33 View Post
    A140 1.4 60kW
    Hi, i have w168 A160 benzin with ECU VDO MAF with the same problem "Start Error".
    ECU MSM 1.4 A 025 545 30 32 (5) and Inmobox 168 820 04 26 5wk4 736
    Mercedes-Benz No.: 02 55 45 30 32
    Supplier: VDO
    Hardware Build Date: 00 / 00
    Software Written Date: 45 / 98
    Diagnostic Identification: 03 / 02
    Fault Codes
    P1570
    P0600 CAN fault The databus is faulty.
    P1650
    P1570
    Can anyone help me to solve this problem?.
    Thanks.
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    check can wires or just test by new two wires from the ecu to the ffz (immo box )
    Jul 2012
    [QUOTE = Pali33; 2214324] Algu?m pode ajudar com este erro de in?cio:
    A140 1.4 60kW
    ECU: MSM1.1 a026 545 05 32 (4) (com flash 20f200)
    Immobox: Siemens 1688200426 5wk4736 (com Motorola 0D69J = HC05x32)
    Na tela ? "Erro de in?cio", o arranque n?o gira, na ECU ? o c?digo de falha "P0600-CAN da FBS (CAN da immobox)"
    Por favor, algu?m pode ajudar?
    Muito obrigado antecipadamente. [/ QUOTE]
    Friend reads the transponder and posts it here
  7. The Following User Says Thank You to DOUGLASDL For This Useful Post:
    AutoElectronicaFS (20th July, 2017)
    Jul 2012
  9. The Following User Says Thank You to DOUGLASDL For This Useful Post:
  10. #8
    Apr 2014
    Quote Originally Posted by DOUGLASDL View Post
    The car only have one key, here is TP and MCU read.
    68hc05x32_d69j_w168_Palmucci.rar
    Thanks for help.
