Hi m8s
This is C. cruze 2.0 diesel vcdi, i need pin code to relearn keys because i have this dtc from ecu P0633- immobiliser key not programmed ECM/PCM.
Thanks in advance
Hi m8s
Thanks in advance
Press "THANKS" button. just one click, CHEERS
alusta (5th December, 2020)
In my country does not cruze diesel.
The address I have for this car pin code, pincode is 9B49, but I think it is wrong because of the "B"
electrones (2nd February, 2014)
here you go,,,,
alusta (5th December, 2020), electrones (2nd February, 2014)
gepakg,
In my country are also numbers, no letters.
Let's see the result.
Thank frriends for help
Mrs Jeanhdo you are funny, so your country not build diesel cars, so you do not know C. Cruze LS diesel, although it is produced in south korea according to VIN.
Cheers
Hi m8s
I tried to programming keys but without success MVP clone does not support this vehicle.
I have "AVDI" but i haven?t ON013 .... but i'll try tomorrow with SBB, car is a bit far.
Today on ECU date display, i saw:
1- programmed security code: YES
2- entered correct security code: NO
3- wait timer security code: INACTIVE
After seeing this I think pin code entered is not correct, because I'm the 2nd person to work on this car.
The 1st person who worked in the car don?t know who is,
I have chances to get pin code starting Vin!?
Someone could help me virgin files, please.
Thanks in advance
sbb wont do this car with vaux com you dont need pin for the cruz only astra j and insignia
x100 can do maybe
I think that the problem is solved_tech
pin code is correct
A topic that interests me
Hi friends
Problem solved, i re-entered the keys and the car ran beautifully
Cheers
Hello.I want to know the security code of my Cruze vehicle. But I can't find it. How can I find.
PİN: KL1JA69E9DK036019
