    Mar 2009
    Portugal
    Default Opel Vivaro Ecu Fault P0606
    Hello friends,i have here one ecu from opel vivaro 2.0cdti year 2008 with bosch ecu with Fault p0606 - Ecu module processor error.engine starts and dies.
    Anyone have similar fault and can this be repaired?
    Mar 2009
    Portugal
    ecu part number - 0 281 014 208
    Feb 2011
    Barcelona, Spain
    It seems a faulty ecu, you try to reflash the ecu completly, maybe the content has been corrupted.
    Aaahh! Verify the injectors are codified corretly.
    Regards.
    Top Poster rozario's Avatar
    had similar problem with same car dont remember now about ecu fault
    but try to open engine plastic cover check injectors they died after water leak if they rusty connect tester on injector connection souldnt be connect to earth
    Above sea-level
    You could try to correct the checksum with bdm100.
    Nov 2011
    friend and friend
    change the electrolytic capacitor friend (big orange) that is by the back of the ecu
    if correct the fault,
    the car starts and stops.
