Anybody uses VAG CAN PRO or if anybody can recommend which device to use to calibrate 2.7 / 3.0 tdi turbo on bench?
The procedure is:
Removing and installing turbocharger control unit 1 -J724-
Special tools and workshop equipment required
t Tester for E-positioner -VAS 6395-
t Connection lead -VAS 6395/2-
t Stop plate -VAS 6395/5-
Removing
– Remove engine cover panel -arrows-.
– Open cover -arrow- above positive terminal.
– Connect tester for E-positioner -VAS 6395- to positive terminal „+“ and negative terminal „–“ with connection lead -VAS 6395/2-.
Procedure for tester for E-positioner -VAS 6395A/1-:
– Select software version with buttons ↑-item 5- and ↓-item 6-.
– To confirm software version, press v button -item 4-.
NoteIn this example, software version Hella -item 1- is selected.
Procedure for tester for E-positioner -VAS 6395/1-:
Checking software version of tester for E-positioner -VAS 6395/1-:
Caution
Risk of damage to turbocharger 1 control unit -J724-.
Before continuing, check whether the correct software version is loaded in the tester for E-positioner -VAS 6395/1-. To do so, proceed as follows:
Display on -VAS 6395/1- (2 seconds after connecting to power supply) if correct software version is loaded:
1 - > 1. START
2 - 2. NEXT [>]
Notet If the following appears on the display, an incorrect software version has been loaded:
t 1. >TEST
t 2. LEARN
t If this is the case, download the correct software version from the „Audi ServiceNet“ under „Workshop Equipment“.
Continued for both testers for E-positioner:
– Unplug electrical connector for turbocharger 1 control unit -J724-.
– Connect connection lead -VAS 6395/2- to turbocharger 1 control unit -J724- and to tester for E-positioner -VAS 6395-.
Display on -VAS 6395-:
1 - > 1. START
2 - 2. NEXT [>]
– To continue, press v button -item 4-.
l The tester for E-positioner -VAS 6395- runs through the adjustment range of the turbocharger 1 control unit -J724- and checks whether the end positions are reached; display indicates „CHECK“.
1 -
2 - [OK]
Notet If the display indicates „[OK]“, the adjustment range of the turbocharger 1 control unit -J724- is OK.
t If the display shows „FAULT [OK]“, tap gently several times on the housing of turbocharger 1 control unit -J724- with the handle of a screwdriver and repeat the check by pressing v button -item 4-.
– Secure stop plate -VAS 6395/5- with countersunk bolts supplied with and screwed into stop plate (8 Nm).
Caution
Measurement errors due to incorrect attachment of stop plate -VAS 6395/5-.
t The stop plate should only be bolted on using the countersunk bolts supplied with the stop plate.
t The stop plate must not be loosened until the work sequence has been completed.
l The turbocharger 1 control unit -J724- moves back and forth between the stops several times to determine the voltage value.
l Then the turbocharger 1 control unit -J724- moves into installation position.
– While the voltage value is being determined, keep tapping gently on the housing of turbocharger 1 control unit -J724- until the display indicates the following:
1 - X.XXX V
2 - [↑][↓][OK]
– Note voltage value.
l Specification: 3.3 ... 3.7 V
NoteIf the display indicates „FAULT [OK]“ or the voltage is less than 3.3 V or greater than 3.7 V, unplug the tester for E-positioner -VAS 6395- and repeat the complete procedure → Anchor.
1 - X.XXX V
2 - [↑][↓][OK]
– By pressing buttons ↑-item 5- and ↓-item 6-, adjust turbocharger 1 control unit -J724- so that coupling rod can be accessed easily for removal.
– Unclip circlips -arrows- and dispose of them, detach coupling rod.
1 - X.XXX V
2 - [↑][↓][OK]
– By pressing buttons ↑-item 5- and ↓-item 6-, adjust turbocharger 1 control unit -J724- so that bolts for -J724- can be accessed easily.
– Disconnect connection lead -VAS 6395/2- from turbocharger 1 control unit -J724-.
Caution
Tester for E-positioner -VAS 6395- should remain connected to power supply.
– Remove bolts -1, 2, 3- and dispose of them.
– Remove old turbocharger 1 control unit -J724- and dispose of it.
Caution
Check that the three insulating washers are fitted between turbocharger 1 control unit -J724- and the bracket.
– Install new turbocharger 1 control unit -J724- in reverse sequence of removal.
– Fit new bolts as follows:
1 - M6x15 with tapered shank
2 - M6x15 with tapered shank
3 - M6x15
– Initially hand-tighten bolts.
l Turbocharger 1 control unit -J724- must rest on retaining plate so there is no play; it must still be possible to move control unit by hand.
– Connect connection lead -VAS 6395/2- to new turbocharger 1 control unit -J724-.
1 - > 1. START
2 - 2. NEXT [>]
– Select menu item „NEXT“ with ↓ button -item 6-.
1 - X.XXX V
2 - [OK]
NoteIf the display indicates „FAULT“, the new turbocharger 1 control unit -J724- must be renewed for a second time.
1 -
2 - [OK]
1 - X.XXX V (voltage determined with first measurement)
2 - [OK]
l Turbocharger 1 control unit -J724- moves into installation position.
– Insert coupling rod.
l Installation position: The thicker eyelet is fitted onto the shaft of turbocharger 1 control unit -J724-.
– Fit circlips -arrows-.
l The circlips must engage audibly.
– Press turbocharger 1 control unit -J724- towards the rear without applying force -arrow- until lever -1- rests lightly on stop plate -VAS 6395/5-.
– Hold -J724- in this position.
– Tighten bolts -1, 2, 3- to 5 Nm.
l Turbocharger 1 control unit -J724- moves back and forth between the stops several times and is adjusted to the voltage value determined with the first measurement.
1 - X.XXX V
2 - [OK]
Notet If [OK] is indicated on display, terminate adjustment → Anchor.
t If „CHECK“ is indicated on display, proceed as follows.
Procedure if display indicates „CHECK“:
1 - [<<<]
2 - CHECK
or
1 - [>>>]
2 - CHECK
– Loosen bolts -1, 2, 3- until turbocharger 1 control unit -J724- can just be moved by applying light force in the direction stated:
l If display indicates [<<<], move -J724- slightly in direction of travel.
l If display indicates [>>>], move -J724- slightly towards rear of vehicle.
l Turbocharger 1 control unit -J724- again moves back and forth between the stops several times and is adjusted to the voltage value determined with the first measurement.
2 - [OK]
Terminating adjustment:
– Tighten bolts -1, 2, 3- to 10 Nm.
1 - X.XXX V
2 - [OK]
– Remove stop plate -VAS 6395/5-.
– Secure electrical wiring with retaining clip -1-.
l Turbocharger 1 control unit -J724- moves to end positions.
NoteIf the display indicates „FAULT“, the new turbocharger 1 control unit -J724- must be renewed → Anchor.
1 -
2 - [OK]
l Adjustment is completed.
– Unplug electrical connectors for tester for E-positioner -VAS 6395-.
Assemble in reverse order.
klonone (1st October, 2016)
Thank you M8, and how much does it cost this set?
miha99 (23rd February, 2014)
And no other alternative ???
Hi cost for this is around ?500.
