Results 1 to 5 of 5
    rdu04's Avatar
    RO
    Default remove dtc p2015
    hello can help me please remove dtc p2015?
    car passat 2005 engine 2,0 edc 17
    read flash with mpps
    VW Hardware Number: 03L907309
    VW Software Number: 0489
    VW System Type: R4 2,0L EDC G000SG
    VW Engine Code: CBDC
    VW System Data: EDC17_CP14
    Flash Attempts: 2 Times
    Flash Programmed Ok: 2 Times
    this is error
    Address 01: Engine Labels: None
    Control Module Part Number: 03L 997 026 C HW: 03L 907 309
    Component and/or Version: R4 2,0L EDC G000SG 0489
    Software Coding: 0000071
    Work Shop Code: WSC 79651 146 06706
    VCID: 336EA8A6522E49B
    1 Fault Found
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 - 000 - Implausible Signal - MIL ON
    Freeze Frame
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 165379 km
    Time Indication: 0
    Date: 2113.14.20
    Time: 19:01:23
    Freeze Frame
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Lambda: 11.8 %
    Lambda: -3.9 %
    Voltage: 0.304 V
    Bin. Bits: 00000000
    Readiness: 1 1 0 0 1
    can help me modified flash or ideea from this error?
  2. The Following 2 Users Say Thank You to rdu04 For This Useful Post:
    gomarota (6th March, 2014), Zeittt (13th March, 2014)
  3. #2
    Feb 2014
    Skopje, R.Macedonia
  4. The Following User Says Thank You to StepOn Chiptuning For This Useful Post:
    rdu04 (5th March, 2014)
  5. #3
    rdu04's Avatar
    RO
    thanks StepOn Chiptuning test and post results but
    check the password please is not good
  6. #4
    Feb 2014
    Skopje, R.Macedonia
    VW Passat TDI_ Flap.rar
    I have forget pass. here new pass
    rdu04's Avatar
    RO
    thanks again
