Results 1 to 4 of 4
    Mar 2014
    Default "USB Device not found. Switching to channel list mode" error with USB Loader GX
    Hello all,
    I'm trying to run an .iso of SSBB on my Wii, but am receiving the error "USB Device not found. Switching to channel list mode" constantly, even while using a device on USB Devices Compatibility List - WikiTemp that is known to be compatible.
    Using USB Loader GX from USBLoader_GX_V3_0_AllinOnePackage_IOS249.zip - usbloader-gui - The ultimative All-In-One package for USB Loader GX v3.0 (boot IOS 249) - USB Loader GX: GUI for Waninkoko?s USB Loader (based on libwiigui) - Google Project Hosting.
    Here is my syscheck:
    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Drive date: 2007.02.13
    Homebrew Channel 1.1.2 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 61142789
    Boot2 v4
    Found 82 titles.
    Found 54 IOS on this console. 5 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug NAND Access
    IOS80 (rev 16174): Trucha Bug NAND Access
    IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS254 (rev 65280): Stub
    BC v6
    MIOS v10
    Report generated on 2014/03/09.
    Please help? Thank you!
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    I don't see anything wrong with that sysCheck. It sounds like you've plugged the drive into the wrong USB socket.
    When you plug it in the wrong one it will only show icons of the Wii desktop. "Switching to channel list mode"
    The only socket that will work is the one nearest the edge (bottom if you mount the console flat) of the Wii.
    Keith
    2010 Golf GTD (170)
  3. The Following User Says Thank You to Keithuk For This Useful Post:
    ThatGun (9th March, 2014)
    Mar 2014
    Thanks for responding! I change the USB socket, and now the Wii recognizes the drive and the game (it shows up on the USB Loader screen as an option) but can't load it (every time I try the Wii restarts and goes back to it's original homescreen with all the channels). There's also no loadscreen for the game (no music or video is played on this kind of screen, it's just black and silent).
    Am using a Sandisk Cruzer Blade 16GB USB drive w/ only SSBB on it, placed through WiiBackupManager in .wbfs format. The USB drive itself is FAT32. Thanks again!
    EDIT: It turns out WiiBackupManager installed SSBB to the wrong directory (not under wbfs). Just changed that and everything was cool.
    Aug 2010
    England
    Well my Super Smash Bros. Brawl - PAL - RSBP01 you have to set the game setting to Force PAL60Hz before it will play. There are a few games you have to change settings.
    Call of Duty: Modern Warfare 3 - PAL - SM8P52 must run with IOS250.
    Boom Street - PAL - ST7P01 - Force PAL60Hz
    Project Zero 2 Wii Edition - PAL - SL2P01 - Force NTSC not Force 60Hz
    Keith
    2010 Golf GTD (170)
