Page 1 of 41 12345611 ... LastLast
Results 1 to 15 of 608
    May 2011
    Default UUSP-S (UPA-USB Serial Programmer-S)
    hi
    New upa with box and new pcb ....wait is over and now on elrasoft.com official website...
    going to order right now...
  2. The Following 2 Users Say Thank You to digimile For This Useful Post:
    cokolo (10th March, 2014), newgeniehex (11th March, 2014)
  3. #2
    cokolo's Avatar
    Oct 2010
    Springfield :-)
    The price is ???
    Nov 2010
    - USB 2.0 and USB 3.0 compatible
    - No power supply required
    - In-circuit connector including 6 general purpose I/Os, overcurrent protected (40mA)
    - 30 pins adapter connector including 20 general purpose I/Os & 6 I/Os from in-circuit connector
    - One 1.2V-5V power supply output, program controlled, overcurrent (300mA) and overvoltage protected
    - One 8-13V/1mA output, program controlled
    - Supports low voltage devices down to 1.2V
    - Self-Test option
    - Can be used with TMS and BDM Lockout Disable adapters
    - Small dimensions 5.5x11.5cm
  5. The Following 3 Users Say Thank You to Repinator For This Useful Post:
    antonypaul (3rd July, 2023), kyawkyaw (1st October, 2017)
  6. #4
    UK East
    been waiting for the genuine ones to come back into stock
    Sep 2013
    Is it in stock?
  8. #6
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Yes in stock price 233.24usd
    Only Hardware no enclosure or box included
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  9. The Following 3 Users Say Thank You to hcip For This Useful Post:
    DashProg (20th September, 2017), Meat-Head (30th March, 2015), Paing Paing (13th June, 2019)
  10. #7
    what diference is between?Same software same function not read secured motorola mcu?
  11. #8
    claudio35's Avatar
    Chile
    Supported Devices
    STMicroelectronics ST62*:ST6240, ST6245, ST6249
    NSC CR16*: CR16HCS5(9), CR16MCS5(9), CR16MES5(9), CR16MFS5(9), CR16MCT5/9, CR16HCT5/9
    Motorola HC05*: MC68HC05B6, MC68HC05B8, MC68HC05B16, MC68HC705B16, MC68HC05B32, MC68HC05E6, MC68HC705E6, MC68HC05H12, MC68HC05L28, MC68HC05P3, MC68HC705P3*,MC68HC05X16, MC68HC05X32
    Motorola HC08*: MC68HC08AS20, MC68HC08AS32, MC68HC08AS60, MC68HC08AZ32, MC68HC(9)08AZ32A, MC68HC908AZ60, MC68HC908AZ60A
    Motorola HC11*: MC68HC11A1, MC68HC11A8, MC68HC11E9, MC68HC11EA9, MC68HC11E20, MC68HC11F1, MC68HC11K4, MC68HC11KA2, MC68HC11KA4, MC68HC11KG4, MC68HC11KS2, MC68HC11KS8, MC68HC11L6, MC68HC11P2, MC68HC11PA8, MC68HC11PH8
    Motorola HC12*: MC68HC912B32, MC68HC912BE32, MC68HC912D60, MC68HC912D60A, MC68HC912DC128A, MC68HC912DG128, MC68HC912DG128A
    Motorola HCS12*: MC9S12D64, MC9S12A128, MC9S12DG128, MC9S12DG256, MC9S12H128, MC9S12H256, MC9S12HZ64, MC9S12HZ128, MC9S12HZ256, MC9S12HY64**, MC9S12HA32**
    Freescale (Motorola) HCS12X*: MC9S12XD64, MC9S12XD128, MC9S12XDG128, MC9S12XDP384, MC9S12XDP512, MC9S12XHZ256, MC9S12XHZ512, MC9S12XDT384
    Freescale (Motorola) HCS12XE*: MC9S12XEG128, MC9S12XET256, MC9S12XEQ384, MC9S12XEQ512, MC9S12XEP768, MC9S12XEP100
    Atmel 8051 Architecture: AT89S51, AT89S52, AT89S53, AT89S8252, AT89S8253
    Atmel AVR 8-Bit Risk: AT90S1200, AT90S2313, AT90S2323, AT90S2333, AT90S2343, AT90S4433, AT90S4434, AT90S8515, AT90S8535, ATmega8, ATmega16, ATmega161, ATmega162, ATmega163, ATmega323, ATmega64, ATmega103, ATmega128, ATtiny12, ATtiny15, ATtiny2313, ATmega8515, ATmega8535
    Microchip PIC12: PIC12F508, PIC12F509, PIC12F629, PIC12F675
    Microchip PIC16: PIC16F627(A), PIC16F628(A), PIC16F648A, PIC16F72, PIC16F73, PIC16F74, PIC16F76, PIC16F77, PIC16F818, PIC16F819, PIC16F83, PIC16F84(A), PIC16F870, PIC16F871, PIC16F872, PIC16F873(A), PIC16F874(A), PIC16F876(A), PIC16F877(A), PIC16F913, PIC16F914, PIC16F916, PIC16F917, PIC16F946
    EEPROMs I2C: 24C01, 24C02, 24C04, 24C08, 24C16, 24C32, 24C64, 24C65, 24C128, 24C256, 24C512, 85C72, 85C82, 85C92, BAW574252, GRM-003, GRM-004, GRM-005, KKZ-06F, MCM2814, PCA8581, PCF8581, PCF8582, PCF8594, PCF8598, PCF85102, PCF85116, SDA2516, SDA2526, SDA2546, X24C00, X24C01, 24C1024, 24C1025
    EEPROMs Microwire: 7002, 93C06, 93C14, 93C46, 93C56, 93C57, 93C66, 93C76, 93C86, 93S46, 93S56, 93S66, GRN-001, GRO-002, KKZ-01, S220, S2914, ST61907, XLS93C46
    EEPROMs SPI: M35080, 25C010, 25C020, 25C040, 25C080, 25C128, 25C160, 25C256, 25C320, 25C640, ST95010, ST95020, ST95040, ST95080, ST95160, ST95320, ST95640, ST95P02, ST95P04, ST95P08, X5043, X5045
    EEPROMs Miscellaneous: CXK1011, CXK1012, CXK1013, M6M80011, M6M80021, M6M80041, SDE2506, TC89101, TC89102, 77005, 77007, BR9010, BR9020, BR9040, CAT64LC10, CAT64LC20, CAT64LC40, S-29190A, S-29290A ,S-29390A
    Serial Flash SPI: M25P05, M25P10, M25P20, M25P40, M25P80, A25L512, A25L010, A25L020, A25L040, A25L080, A25L016, A25L032, SST25VF512A, SST25VF010A, SST25VF020B, SST25VF040B, SST25VF080B, SST25VF016B, SST25VF032B, S25FL004A, S25FL008A, S25FL016A, S25FL032A, S25FL064A
    *EEPROM Only
    **D-Flash Memory only
    I see this difference 1.3:
    Freescale (Motorola) HCS12XE *: MC9S12XEG128, MC9S12XET256, MC9S12XEQ384, MC9S12XEQ512, MC9S12XEP768, MC9S12XEP100
  12. The Following User Says Thank You to claudio35 For This Useful Post:
    jasimkhan (13th February, 2016)
  13. #9
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    no incircuit dongle needed anymore ?
    "- USB 2.0 and USB 3.0 compatible
    - Self-Test option
    - Small dimensions 5.5x11.5cm"
    Reading is fundamental, asking is easy............................
  14. The Following 2 Users Say Thank You to XmoDDeR For This Useful Post:
    fhwong (24th May, 2022), marikette (6th January, 2024)
  15. #10
    DK Veteran chrismoore02's Avatar
    Jul 2011
    England
    Good spot xmodder looks interesting
  16. #11
    DK Veteran gjuzel's Avatar
    Nov 2011
    (North Macedonia)
    new upa usb-s PRICE IS ...
  17. The Following User Says Thank You to gjuzel For This Useful Post:
  18. #12
    Lexas's Avatar
    ****ing idiots. just bought one (old) and next day they was out of stock. thought i was lucky and bought last one... they should let me know that new version on the way after couple weeks. bastards... no respect for them anymore
    Don't Forget Button
  19. The Following 5 Users Say Thank You to Lexas For This Useful Post:
    KevinXTR (14th September, 2016), Meat-Head (30th March, 2015), mohamedkey (27th September, 2015), munsif butt ksw (21st May, 2015), rapidsat (17th December, 2018)
  20. #13
    Dec 2010
    vietnam
    it is compatible with the old adapter?
  21. #14
    hello
    the old scrypt uds or udx work whit the new hardware and software?
    thank in advance
    regard
  22. #15
    UK East
    Will find out when one of us gets the new version and tests it. Wonder what the 'S' denotes on the end of the product name?
