Results 1 to 13 of 13
    Mar 2013
    Europe
    Default Fiat Ducato 2012 Please correction
    i need mileage correction on Fiat Ducato 2012 95160
    Ori KM = 37434
    i need = 12434
    222224_S95160.rar
    THANKS
    autoecu's Avatar
    Dec 2013
    turkiye
    Default Fiat Ducato 2012 L?tfen d?zeltme
  3. The Following User Says Thank You to autoecu For This Useful Post:
    bersch8688 (12th March, 2014)
    Mar 2013
    Europe
    THANKS WORK PERFECT
    Mar 2013
    Europe
    Fiat Ducato 2012 in Men? 95160 not work digiprog say "0KM"Need read eeprom in eeprom men? and edit and write
    Nov 2015
    Can someone please tell me If 2014 Fiat Ducato mileage stored in the Ecu Or Dash ?
    Thanks in advance
    Dec 2015
    ecu and dash
  8. The Following User Says Thank You to tavicu21 For This Useful Post:
    manmario (29th December, 2015)
  9. #7
    dash, ecu, dpf and error clear
  10. The Following User Says Thank You to vageric For This Useful Post:
  11. #8
    Nov 2015
    Do I have to read ecu eeprom and Dash eeprom with eeprom programmers ?
    I'm asking this because in North America It's called Dodge Ram Pro master not Fiat Ducota
  12. #9
    Quote Originally Posted by manmario View Post
    yes you need to read dash eprom for changing mileage. (most devices can do it through OBD these days).
    then you need to read ecu eprom for changing mileage, dpf, oil service.
    then error clear through OBD.
  13. The Following 3 Users Say Thank You to vageric For This Useful Post:
    galaxy0634 (29th December, 2018), manmario (30th December, 2015), pike (30th December, 2015)
  14. #10
    Nov 2015
    Do you know which tool I can use it to read through obd , I have ori avdi and tried to use Dodge fuction to read the mileage It doesn't work
  15. #11
    what does'nt work?
    it give error or dont read right mileage or what?
  16. #12
    last programming mileage in ecu, last inspection mileage-date-number, some srs-ecu have mileage...
    You have mileage calculator to Continental SID208 or Visteon DCU102?
  17. #13
    Quote Originally Posted by tomlib View Post
    no dont have.
