Results 1 to 5 of 5
    Default Nissan Micra K12 1.4 ECU Swap
    Got a Micra K12 1.4 with Faulty ECU. Got a complete ECU set from the breakers (ECU, BCM, Steering lock, Central locking box, Fuse box, Instrument Cluster and the Smart Key).
    Fitted all even though I am sure I did not have to change the Fuse Box or the Instrument Cluster. Car locks and unlocks with the supplied key, when you get in the car the "Green" KEY lights up but the moment you try to start the car the red key symbol show and nothing happens.
    Tried to re-program the key with the 12 digit Sec which I got using ICC after reading 93C66 form the ECU and got incorrect sec code.
    Is it possible that the Power Steering is stopping the car from starting and stopping the key getting programmed.
    If so can the Power steering be reset or Virginlised?
    Any help will be greatly appreciated.
    I am working on simular projects.
    I would first - post the 12 dig number on the label in the glove box and get the 12 dig code confirmed.
    As they are noted for loosing their keycode I would try to re-code the key, to be honest I dont think it will solve the problem.
    Get a used ecu with the same part number and swap the eeprom, if faulty ecu is just the problem then the car should start.
  3. The Following User Says Thank You to albertros For This Useful Post:
    gurmk (26th March, 2014)
    Glove Box, that's the first thing I looked for but it was missing hence the reason for getting the pin code from the ECU
    dewsbury west yorkshire
    swap the eeprom on ecu should all be ok
  6. The Following User Says Thank You to dashtec For This Useful Post:
    gurmk (28th March, 2014)
    Feb 2017
    Quote Originally Posted by gurmk View Post
    Hi I dont know if you have sorted it, i had similar problem ,you need to virginise power steering, mine started today
    good luck
