Page 92 of 95 FirstFirst ... 4282878889909192939495 LastLast
Results 1,366 to 1,380 of 1425
  1. #1366
    Hello!
    After reading all the pages on this topic, I created a shopping list(Mouser) to rework my galletto and I need your help.
    1. What is the package and the type of the missing 4.7K resistor?
    2. On mouser the minimum quantity for LP2951ACM is 665... What is the difference between LP2951ACM and LP2951ACM/NOPB?
    Best Regards
  2. #1367
    Jan 2019
    Best Country of the world, GR
    Quote Originally Posted by papalos_ View Post
    Hello!
    Best Regards
    farnel have without quantity https://uk.farnell.com/texas-instrum...951/dp/9493425
    but I think it is same /NOPB.
    Which resistor do you mean?
  3. #1368
    Jan 2019
    China clone v54 I check the ohm of grey boot wire and the switch of db15 connector...
    Results
    0 Ohm and without switch cut...
    How bad is if the grey boot wire has 0 ohm resistance?
    The switch of connector db15, which wiring should stop?
    Unfortunately killed an ecu...only on tricore reading..
  4. #1369
    Jun 2013
    EU
    Grey wire should have 1kohm in relation with gnd.
    Switch in db15 cable should cut positive of +12v to the ecu side.
  5. #1370
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by gas43 View Post
    Results
    Check cable is wired correctly inside 15way plug
  6. #1371
    Jan 2019
    Quote Originally Posted by morgano View Post
    Quote Originally Posted by teerak2uk View Post
    Guys, bad news,
    I open the 15way plug and the resistor was in wrong position....it was between orange wire(CAN-L) and blue wire...by the way I tested the resistor with mulimeter and was 4Kohm...
    the switch does not cut red wire +12volt, only cut the white external 12volt adapter....
    OMG
    Anyone who buys china v54 please test the 15way cable...
    Now the ecu is stuck in boot mode and car dont start, no communication via obd.
    In boot mode continues read and write...but car dont start...
    Is there a solution? or ecu is dead?
  7. #1372
    Jun 2013
    EU
    120 ohm is the value of the resistor thst bridges blue and orange wires. Can bus termination resistor.
    The switch may let always feed the fgtech while connected to externall supply on the breakout cable, not the dcjack on the fgtech itself, and just cut the 12 volt to the ecu going red wires.
    The 4k tesistor is wrong value.
  8. #1373
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    This should help also Kline is green not ignition
  9. The Following User Says Thank You to teerak2uk For This Useful Post:
    turbo16v (26th February, 2020)
  10. #1374
    Jan 2019
    Understand,
    120 Ohm between orange and blue wire
    1000 Ohm gray boot wire
    switch must cut +12volt red wire
    everything wrong in china v54...
  11. #1375
    Jan 2019
    Which wire is ignition?
  12. #1376
    Jun 2013
    EU
    Ignition wire is same as kline (green) but is only used as ignition while doing tricore bootmode.
  13. #1377
    Jan 2019
    Ok
    that I thought
    thanks!
  14. #1378
    Jan 2019
    I am looking for these resistors,
    what Tolerance need? 0.1%, 1%, 5%?
  15. #1379
    Jan 2019
  16. #1380
    Mar 2019
    Quote Originally Posted by mislav88 View Post
    why have you set voltage to 3.3?
    just use good old bdm100, never failed me
    8999okoopl0oi9oool
