Results 1 to 15 of 19
    dunkler's Avatar
    May 2009
    Hatzfeld
    Default E60 Airbag module repair 93F9
    I have a BMW E60 '05 which has a fault code stored "93F9 - Low Reserve Voltage" and cannot be cleared. After I've searched on google I think it has something to do with backup power and some faulty capacitors. Does anyone have any ideea about this, do I need to replace those capacitors or rewrite a good dump? Car have been reflashed so I don't think it's a firmware issue
    LE: Problem solved, changing the capacitors will cure fault 93F9. 8200uF 63V 35x35. I attached a photo with them, good luck
  2. The Following 23 Users Say Thank You to dunkler For This Useful Post:
    ali7697 (19th September, 2022), autocentarvu (21st January, 2016), Bimm (6th November, 2023), bmwkastela (29th November, 2017), BusCan (28th April, 2018), danielgatan (11th July, 2019), darwins (14th August, 2016), erwann (9th July, 2020), FxShaw (15th March, 2016), g5n14 (25th September, 2023), GameTheoryOptimal (16th June, 2018), gomarota (24th January, 2017), Ianse60 (15th August, 2016), mexanico1971 (6th April, 2017), Plcautoparts (16th March, 2016), raceshadow (27th February, 2020), rimljan (27th November, 2018), Tzepy (25th July, 2014), UnDeR_ScOr3 (4th July, 2016), vas100 (25th March, 2023), wokounek (29th October, 2014), _estima_ (14th December, 2017)
  3. #2
    Jan 2016
    Hi, thank you for repair solution.
    your airbag SGM still No faults? (after replacing capacitors)
    how did you remove capacitors from the electrical board, capacitors are glued with epoxy.?
    Thank you in advance.
    Mar 2016
    Thank you. Going to give this a try...
    dunkler's Avatar
    May 2009
    Hatzfeld
    Usually 83F9 will go with new capacitors but had one module which I've had to reball the CPU, strange. No errors so far
  6. The Following 3 Users Say Thank You to dunkler For This Useful Post:
    chipcarcordoba2 (26th May, 2020), FxShaw (20th March, 2016), UnDeR_ScOr3 (5th July, 2016)
    Hi dunkler
    What do u mean reball cpu? Is it the same as flashing it? Rewrite firmware?
    Is it easy to open the module? What about desolderind and soldering back the capacitors? Easy? Difficult? Do you need any special equipment? How many capacitors does it have?
    Sorry for so many questions. Really need some help with this.
    Would two of these do the job?
    Thanks in advance.
  8. #6
    Anyone? please...
  9. #7
    Dec 2016
    Is it easy to remove the old capacitors. I'm getting fault 93f9, voltage of reserve energy v60 n.i.o. Really interested if it can be repaired
  10. #8
    Dec 2016
    Reballing is done a lot with computer chips, where controlled heat is applied to chips, to hopefully repair any cracks in the solder joints within.
  11. #9
    May 2017
    Hh vbnnnnn
    Envoy? de mon iPhone en utilisant Tapatalk
  12. #10
    Did you use 105c capacitors or 85c?
  13. #11
    BusCan's Avatar
    Nov 2013
    Default 93F9
    I encountered the same problem on a BMW E60
    I changed the capacitors without result
    The problem and the BST
    After change all and OK
    Good luck
  14. The Following 2 Users Say Thank You to BusCan For This Useful Post:
    Min2xx (10th May, 2018)
  15. #12
    BusCan's Avatar
    Nov 2013
    Hello everyone
    Eventually the problem persisted 93F9 return code
    The solution I replaced them with an opportunity and reprogrammed and all and OK
    I think the BGA and cause it's malfunction!
    Good luck
  16. #13
    Jun 2018
    I have them same problem and I hope changing the capacitors will solve the issue.
  17. #14
    BusCan's Avatar
    Nov 2013
    Quote Originally Posted by WackyII View Post
    hi
    I changed the capacitor that did not change anything.
    I change ECU and all and returned to order
    Good luck
  18. #15
    Jun 2018
    Hi dunkler! I have same problem than you. I can see your attached photo. Where is this module in bmw car?
