    Default Nissan Bosch LCN is locked
    hi friends
    I need your help to unlock Nissan LCN Bosch 7 612 890 092
    when I power this unit on there is an error message on screen (( Incorrect PIN entered too many times. system is now locked. contact your Nissan dealer )) how can I solve this problem
    and to have new chance to inter pin code
    and how can I obtain pin code
    I attached pictures for the error message and the PCB and the label of this unit
    I will be thankful for your help
    M1DJF's Avatar
    West Yorkshire
    You will need to read Omap mcu and upload dump here
    If you can't repair it, leave it as you found it, don't destroy it.
  3. The Following User Says Thank You to M1DJF For This Useful Post:
    naelraddad (21st April, 2014)
    Bulgaria
  5. The Following User Says Thank You to bogege For This Useful Post:
  6. #4
    thanks friends for your reply
    which one is the Omap Mcu and which programmer can read it
    regards
    Faraday's Avatar
    May 2012
    The dark side of the moon
    If you can't find OMAP then better take your radio to decoder service.
  8. #6
    siti's Avatar
    RO-ALBA
    code & reset locked in flash gl512........
  9. The Following User Says Thank You to siti For This Useful Post:
    kappa1 (22nd April, 2014)
