Results 1 to 8 of 8
    Mar 2014
    Glasgow
    Default Permanent VFD Clock
    Hi has anyone got this plug in as my ibox 2plus is not displaying channel numbers.
    Apr 2014
    Depends what image version ur using if it works or not. I found it using tspanel in the plugins section
    Member thevilla1's Avatar
    Dec 2008
    Quote Originally Posted by sucmnsee View Post
    im using openvix..but as i have azgemma box (not supported by openvix) plugin downloads dont work.. ive been using the clock plugin for about a year..so works fine with vix and gemma... but i updated to latest vix and now i cant download it anymore.... i only have 4 plugins that i use...ccam / mgcamd / clock / red hd skin / only the clock missing
    digicon's Avatar
    Jul 2009
    as you already noted OpenVix put the brakes on the loophole to the plugin server downloads your only option is to find the plugin as a .ipk installer or change your image
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    If you still want to use an unsupported Openvix, here's a cheeky little cheat you can do if your having trouble google searching for the .ipk file, all your doing is pinching the latest .ipk file off the openatv feeds, good for future updates
    1. Download a base Openatv image from the zgemma.tv website
    2. Install and complete the config screen
    3. Telnet to your Zgemma using your PC by opening a command prompt(admin) and
    i. Type 'Telnet' and the IP address of your zgemma and press return
    ii. Type 'root' and press return
    iii. Type 'opkg download enigma2-plugin-extensions-permanentvfdclock' this will download the latest .ipk file to your Zgemma
    iv. FTP to /var/volatile/cache/opkg and drg the .ipk file to your PC's desktop
    4. Flash Openvix and FTP the .ipk file to your Zgemma and install via the local extensions menu
  6. The Following User Says Thank You to martin035 For This Useful Post:
    digicon (16th October, 2016)
  7. #6
    digicon's Avatar
    Jul 2009
    to save the hassle
  8. The Following 2 Users Say Thank You to digicon For This Useful Post:
    happy_highlander (27th June, 2017), martin035 (16th October, 2016)
  9. #7
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by digicon View Post
    to save the hassle
    Sorry digi can't resist............................
  10. The Following User Says Thank You to martin035 For This Useful Post:
  11. #8
    Dec 2008
    to save the hassle
    many many thanks...dont like openatv..the odd foreign words appear in the settings etc
    and im used to openvix now thanks again
