Results 1 to 15 of 17
    Default TOYOTA PRIUS 2010 DASHBOARD PINOUT
    Hello I need to test in bench Toyota Prius 2010 Dashboard...I have not find pinout for this model....found others with other type plugs (2001-2004 -2007 pinouts) bu this model seems newer. I upload photo so anyone could help.
    Need to test in bench, screen is black, suspect some FET and very very bad soldering issue...but need pinout to check Vdd.
    Thanks in advance.
    Sep 2010
    Spain
    Did you solve the problem , power pin and repair dash?
    Thanks!!
    lwood's Avatar
    city of angels
    Quote Originally Posted by GolfmkI View Post
    Thanks in advance.
    i posted power ups here for 2010-up Prius.
    http://www.digital-kaos.co.uk/forums...ml#post2307070
    DON'T JUST SAY PRESS IT.....
  4. The Following User Says Thank You to lwood For This Useful Post:
    SARGIAN (21st March, 2020)
    Canada
    post the pic of back of the board
    If i helped you please press thanx
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default dashboard
    picture 1 resolder all resistors to display ....see carefully all board ......cold point 100%
    see black line.....
  7. The Following 9 Users Say Thank You to vasko For This Useful Post:
    brend (13th February, 2023), capi (15th May, 2015), danielif (26th August, 2015), line44 (29th March, 2021), martinracing (10th November, 2017), SARGIAN (21st March, 2020), sarigol45 (1st June, 2018), satesquio (14th April, 2016), xifly18 (29th May, 2015)
  8. #6
    klonone's Avatar
    hello, please need pinout for dash
    please ,what mosfet replace???
  9. #7
    uk
    here is power up..
  10. The Following 11 Users Say Thank You to raf0468 For This Useful Post:
    angelo44 (10th March, 2019), brend (13th February, 2023), capi (16th June, 2016), clauberty (4th June, 2019), dziuggy (28th December, 2020), greg6969 (5th November, 2020), klonone (11th August, 2022), martinracing (10th November, 2017), PETAR (21st November, 2023), SARGIAN (1st February, 2019), sarigol45 (1st June, 2018)
  11. #8
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by raf0468 View Post
    here is power up..
    Hello
    Can you send me please this meter dump file 93c86 mileage dump
    Sent from my C5502 using Tapatalk
  12. #9
    here is your file
  13. The Following 2 Users Say Thank You to nikz For This Useful Post:
    digikeys (21st September, 2016), SARGIAN (1st February, 2019)
  14. #10
    Oct 2018
    United Kingdom
    Is it +12V on Pin19?
    Thanks,
  15. #11
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by TOYOTA7865 View Post
    Thanks,
    yes it is 12 Volt
    Don't forget the magic button !
  16. The Following 2 Users Say Thank You to bidu20 For This Useful Post:
    SARGIAN (29th January, 2019), TOYOTA7865 (9th October, 2018)
  17. #12
    Sep 2020
    hello
    i have connected pin 19 to +12v and pin 30 to ground and the dash don't light up
    the charger is 12v 2a, do you thimk that I have to use more amps ?
  18. #13
    Nov 2020
    Quote Originally Posted by carcotashul View Post
    hello
    No 2A is more than enough.
  19. The Following User Says Thank You to Malik57 For This Useful Post:
    carcotashul (13th December, 2020)
  20. #14
    Sep 2020
    Finaly I have solved this, it is working
    the next problem I have is that i got 2 dashboards
    the first is from a car left hand drive , i have connected pin 19 to + and pin 30 to ground and the dash non't light up
    the second one is from a car right hand drive , also i have connected the pin 19 to + and pin 30 to ground and this one works
    is there a way that the pins are not the same?
  21. #15
    Sep 2020
    I have renew the all tre soldering from the marked area , after connecting the + to pin 19 and the ground to pin 30 the dashboard started to work again but after leaving it for couple of minutes disconnect from the power and connect it again it won’t work
    What can be the problem?
