Results 1 to 10 of 10
    Spain
    Default CLONING BMW E36 MS40.1
    hello friends.
    I have to clone a ECU from a bmw e36 ms40.1.
    I changed the flash 28f512 .
    Changing the flash it is enough?
    thanks a lot!!!!
    Spain
    Can anybody help me?
    bram380's Avatar
    Indonesia +628153111774
    MS40.1 with flash eeprom, just change flash 28f512 from old to new ecu.
    Spain
    OK, thanks!!!
    Spain
    Hello friends!!
    The car doesn't start.
    Immo is active.
    Engine starts a moment and Stop!!
    Can someone help me?
    bram380's Avatar
    Read flash dme and mcu ews.
    Post here both dumps.
    Spain
    But a question ...
    If I put the flash in the new ecu , the flash is already paired with ews, no?
    Why i doesn't start?
    With the old ecu,and same flash the car starts .
    The problem in the old ecu, is the engine not accelerate.
    Oct 2013
    Did you use a BMW compatible scanner (like INPA, GT1, SSS) and read any code? Try alignment again. And make sure the VIN and ISN are same. If you don't know how to verify VIN and ISN, post the dumps.
    Spain
    Hello.
    The e36 is 1994 year .
    It hasn't ews II. it has kba 9540 box.
    How can i disconnect the kba 9540 box?
    Thanks!!
    Oct 2013
    Quote Originally Posted by hector View Post
    Hello.
    Thanks!!
    I don't have experience with kba box
    But I'm sure you can google that easily.
    Or you find find an older red DME and it will start the car because it has no immo system
