Results 1 to 15 of 15
    Mar 2012
    Slovenia
    Default Megane 2 power steering fault DF035 and DF002
    Can anyone please help me with my renault megane 2 power steering. (8200 246 613B) 50300374 (LHD)
    I have "STEERING FAULT" on dash and DF035 and DF002 errors (sterring is stiff)
    I can't do calibration of steering angle with clip.
    If I try fo fill 24C16 with all-FFs (as some suggest) than I get unrecognised ECU.
    Can someone please help me with obtaining vergin or working dump for this ecu.
    Thank you.
    Mar 2012
    Slovenia
    Problem solved....
    I got donator file from scenic with different ecu number (8200035272) and it works ok now.
    It is not virgin but it works OK. This ecu doesn't have immo like new ones...
  3. The Following 2 Users Say Thank You to miki18 For This Useful Post:
    pbn (25th September, 2014), thurgau (19th June, 2014)
    Dec 2012
    EU
    all ffffffffffffffffff only works for steering lock!
  5. The Following User Says Thank You to gttuning For This Useful Post:
  6. #4
    Dec 2011
    Quote Originally Posted by miki18 View Post
    Problem solved....
    Hi m8,
    I have to same problem, steering sometimes working good, sometimes not
    DF035 DF002 code after clear codes working normal, when start the car p.a.s is gone
    Can you share your dump please
    Mar 2012
    Slovenia
    No problem. Here is my dump (still working :-) )
    Sorry for late repply. I was out this week.....
    Hope it works for you.
    I have one other steering assist in garage so I can read that eeprom if this one doesn't work.
  8. The Following 24 Users Say Thank You to miki18 For This Useful Post:
    Alex321 (19th September, 2014), badfree (22nd November, 2024), BeianM (3rd September, 2014), bokilee (26th July, 2017), BrajoTDI (9th March, 2025), conan981 (1st March, 2019), danis11 (29th June, 2023), Donabe (19th March, 2019), DOUGLASDL (20th September, 2017), elecautocr (14th July, 2017), junnnior (2nd March, 2021), jurlak1 (9th December, 2019), kasim_izmir (24th June, 2023), kona4 (25th May, 2016), martinracing (1st May, 2016), miloudmess (7th March, 2018), OFFIMO (4th March, 2015), paulolad (30th August, 2023), pbn (25th September, 2014), rimljan (1st April, 2015), robert1966 (27th February, 2025), srht61 (14th December, 2024), talhatufan (9th May, 2018), Traks (14th June, 2020)
  9. #6
    DK Veteran BeianM's Avatar
    Dorset UK
    My Scenic had the same faults as above
    DF035 and DF002
    I tried this dump & the fault did not appear on the dash until I touched the steering wheel! So this did not work.
    I can edit the file in clip so it has programed correctly
    Has anyone got a working file for :
    TRW 8200 035 273
    mine is here if you can correct it or post a virgin.
    many thanks.
  10. #7
    Dorset UK
    Just thought I would bump this before I go buy another unit. Unless someone can tell us how to fix it?
  11. #8
    dadal's Avatar
    Aug 2015
    does someone know what is the case/reason of these fault codes, hardware or software problem and case/reason ?
    def048 DF035 DF002 DF053
  12. #9
    Dec 2018
    Hello
    I have the same problems DF035 and DF002 with my scenic 2 . can you tel me the dump for 24c16
  13. #10
    Aug 2019
    If anyone has df035 problem it's recommended to check mosfet area for cracked solder joints
  14. The Following User Says Thank You to zbikawa For This Useful Post:
  15. #11
    May 2013
    I can confirm, that dump from post #5 works fine. VIN number is different, of course, but it doesn't matter. I have Scenic with power steering #8200035272 and DTCs df002 and df035. I believe, that cracked mosfets soldering (as it was told in post #10) causes df035 and as a result df002 is stored too. And df002 often can not be erased, therefore 24c16 dump must be corrected.
  16. #12
    Jul 2020
    Can anyone post a picture of where on the board we need to check for solder joints?
  17. #13
    Sep 2024
    Connection for in-circuit programming eeprom
  18. #14
    Sep 2024
    All places where power components and jumper tracks are soldered.
    Transistors, relays, places where they are connected to the motor.
    Or at least those places where there are traces of ring cracks in the soldering places.
  19. #15
    Oct 2024
    Hello. If you can share with me a working memory dump please. I have the same errors and also Renault Megane 2
