Hi friends, i had find some website sell Autocom CDP+ 2013.03 and Delphi Ds150 scanner? it is looks similar, anybidy use and which one more better? i want buy one![]()
Both the same I think. The single PCB version is the one to get.
what's your mean about "single PCB version" ?friends
Single PCB means single Printed Circuit Board. This is supposed to be the better of the two as I have read that some of the two PCB units problems arise when updating firmware.
Regards.
Never had a problem updating a double PCB unit only one that's ever given me trouble is single pcb plastic case with the black rubber on it.
1 PCB is better, 2 PCB is modification by China
OEM is only 1PCB
BR
Do you have good seller cdp+?
I have delphi ds150, which is actually ds100 made for PC. cost 60usdand works like a charm.
Yhean requires some PC skills and intuition to get it properly installed. as chinese suck at explaining it.
PS i have version 2013.3 and i think 2014.1 just came out
Mates!
Give me seller with good cdp+(ds150e), because I bought some cdp+ with 2 PCB and all working perfect ( ford working perfect too) except BMW e60, I want to buy with 1 PCB and working all
I bouhgt from OBD FOX TECH
just wait a few weeks for new version to come out
Chinese sellers all say that primary function of these devices is to diagnose faults, read and clear fault codes and they cannot ensure other advanced functions these interfaces have, like component coding and adaptation...
Friend of mine had a golden version with oki chip (supposedly the best!) and still he could not do something as basic as injector coding...
Any experience with this? Other people here can use these tools for coding/adaptations, without problems?
Supossedly, new versions dont need oki chip to work well with all cars...
I have a CDP 2013 1 pcb, coding injectors works
i have cdp pro (gold) 2 pcb with oki 2013.1,
work on all car i have tested.
psa renault injector coding is ok
vag adapdation ok
but for specific adaptation like activate cruise control or dpf off it doesn't work
need to use specific tool for brand (pps, vcds, clip...)
Please provide a serious and good seller of either of the devices.
