Results 1 to 12 of 12
    Feb 2014
    Default channel list no HD
    is there a channel list been done with no HD channels on it after all they are going 1 by 1 so it would save messing about with them every other day and if you have a decent tv theres not a whole lot of difference and yes i no there is technically.
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Might be quicker and easier to do one yourself, either download AJ's or Sattv5's latest list and then edit the list yourself using this tool (mediabox editor studio) to remove the HD channels.
    MediaBox Editor Studio (v1.10) - Downloads - Digital Kaos
    Feb 2014
    thats what 1 was thinking martin was hopeing a pro ad done 1 thanks will av a go at it
    Sep 2008
    Quote Originally Posted by martin035 View Post
    Hi Martin this MediaBox Editor is foreign how do you convert it to English ?
    DK Veteran bigade1's Avatar
    Oct 2013
    Top Left Hand Corner - Options ( Fourth Menu Along The Top ) - Language - English
  6. The Following User Says Thank You to bigade1 For This Useful Post:
    redralph (22nd May, 2014)
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by redralph View Post
    Options > language > English.
    edit...just beaten to it by bigade1 .
  8. The Following User Says Thank You to Hadron For This Useful Post:
  9. #7
    May 2012
    Quote Originally Posted by hfxlad View Post
    thats what 1 was thinking martin was hoping a pro ad done 1 thanks will av a go at it
    this seems the best option mate, i have tried that mediabox but keep getting "mismatched file" when i try to update, i have taken all the channels i don't watch out with mediabox, followed the guide, just wont work !!
  10. #8
    Oct 2013
    Quote Originally Posted by johnna2112 View Post
    Are you sure that you've renamed the finished file extension back to .dbs when you've finished editing it? If you've left it with the .abs extension then that would give a " mismatched file " error.
  11. #9
    May 2012
    Quote Originally Posted by bigade1 View Post
    no but what i done was copy & paste the from the guide, i have just noticed the file is named dbs but dbs in in caps ! will this make a difference ?
  12. #10
    Oct 2013
    I wouldn't have thought so - but just to be certain - simply rename it to TP_PROG.dbs and see if that makes a difference.
  13. #11
    May 2012
    where is that mediabox guide post? been searching for ages , edit , found !!!
  14. #12
    May 2012
    job done , only 56 channels in the box now, all the stuff gone i don't watch, no hd all sd so got missing channels back, good bit of kit that mediabox
