Results 1 to 15 of 21
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default Help Renault kangoo 1.9d
    Hello i need your help, reviews and experiences.
    I have in my garage a Renault kangoo 1.9d f8q pump lucas epic. The car was in two garages before came to me, a friend give me the car to repair because he can't do it.
    The car not start and in ecu (DCU3R) only have one DTC DF066 (Fuel flow actuator position; incorrect position).
    The owner said that in the first garage they change 3 pumps from scrap and the problem persist, and my friend (second garage) change 2 pumps and he had same problem, the car not start and same DTC DF066.
    Then now the car is my garage, i have two pumps (from my friend of second garage) and i reset memory of pump sensor (OSM), but the car continues with same problem...
    Maybe i doing something wrong... the car not have inmobilizer problem, i do test with and without transponder and i see authorization start value.
    The wiring is checked too.
    Can any tell me more info about this pump and OSM sensor. The car without calibrate OSM must start? i believe will must start (not idling well, maybe)
    Apr 2014
    if you loosen the fuel injector metal pipes does diesel come out when cranking?
    what is the red imobbiliser light doing on the dash when cranking?
    Jul 2013
    yorkshire
    DO NOT TRY THIS. NEVER SLACKEN OFF FUEL INJECTOR PIPES ON HDI. there is enough pressure in there to KILL you. look in live data if you want to see the fuel pressure etc. The metal pipes are a one time fit only. Plus once you undo the pipe the pressure has gone so it proves nothing.
    autoden
    mne,bp
    lucas epic pumps works at max 150bar....
    Moderator
    PremierD's Avatar
    Jun 2009
    Lets stick to the original topic please chaps ......
    Meat-Head's Avatar
    Quote Originally Posted by PremierD View Post
    On TOOIC :-
    so the sensor it's moaning about have you googled it, see if you can fiver out the connections it has/should have
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    ruffles1986 (24th May, 2014)
    Apr 2014
    F8Q isnt hdi
    if the fuel was coming through from the pump to the injectors you can rule out an immobiliser problem, if it wasnt you could remove the sheer nuts and cover on the pump to reveal the solenoid and remove the electrical connections to it and just fit a switched live to it a
    Meat-Head's Avatar
    On topic
    thought Lucas epic pump 'doesn't have' a solenod just fuel adjust advance/retard
  10. #9
    Apr 2014
    the immobiliser stops the ignition live to the pump . i think it has a advance/retard valve but also a stop solenoid which is controlled by the immobiliser / ignition switched live
  11. #10
    Sep 2011
    In the Garage
    On TOOIC :-
    i have the wiring diagram from this inyection pump and was checked. I think the fault is inside the ECU, maybe any had a similar issue.
  12. #11
    Sep 2011
    In the Garage
    Quote Originally Posted by sjc1 View Post
    Inmobilizer was the first thing was checked, red light is off when turn on ignition, anyway i try with and without transponder and y see values of authorization start, then i discard inmobilizer
  13. #12
    Meat-Head's Avatar
    Can you share the diagrammed please WITH NO PASSWORD.
    see if you can swap the ecu
  14. #13
    Sep 2011
    In the Garage
  15. The Following 7 Users Say Thank You to ruffles1986 For This Useful Post:
    BusCan (24th January, 2017), Kinred (20th February, 2018), martinracing (18th March, 2015), Meat-Head (25th May, 2014), mexanico1971 (4th September, 2018), rrr500 (27th June, 2018), thurgau (10th December, 2015)
  16. #14
    Oct 2013
    GB
    I have same problem. the same symptoms filings in the tank . Cleaning the tank and piping change( ecu )that is the problem
  17. The Following User Says Thank You to nikostzimis For This Useful Post:
    ruffles1986 (28th May, 2014)
  18. #15
    in this injection system if even one injector have problem,ecu cut the hi presure. so the best solusion is unplug injectors and pump-go to diesel spesialist for check and if everythingis ok move to the next part.
  19. The Following User Says Thank You to zoyzoyni For This Useful Post:
