hi
Does anyone have a tested procedure for programming remote for LEXUS RX400H / 2007 ?
I tried a few ways but unsuccessfully
hi
PUSH reputation and thanks If you think I helped .............................
needs diag tool, T300 can do it even, remote type 2
new remote will be easy, used...... almost no chance
yes, is TOY48 key with a 4D68 chip
I tried program used remote
If is a slot type key, used will be difficult.
Otherwise, normal remote no problem![]()
Need to use the proper RHK , should have a (power door) button. OBP will work if you follow the process to the Tee.
try manualy
and whit t300, sbb
with the manual procedure the car entered in the programing mode by locking/unlocking the doors?
no , no entered
The car has already a remote key that is working? If not chack the fuses and do a diag.
car key with remote control has a functional
spare key he received after
But received key is from another car
I programmed chip
but the remote can not be programmed
car does not enter programming mode
Do you have Toyota Techstream to try with? https://www.youtube.com/watch?v=8SivdN83i4E
