Results 1 to 15 of 30
    soxten's Avatar
    Mar 2013
    Default Help to repair ABS unit Bosch to Rover 75
    I have a Rover 75 with a broken ABS unit.
    Bosch 0265800001
    Fault is that abs pump is working all time.
    I have open abs unit and check solder and broken wire but all is ok!
    Do some one know how to find this fault and if it possible to repair?
    Christian Johansson via Iphone 5s
  2. The Following User Says Thank You to soxten For This Useful Post:
    shadow12 (28th April, 2016)
  3. #2
    there are motor driver mosfet's under al block
    Meat-Head's Avatar
    Somebody else had this, good excuse to dk search MOSFET (metal oxide seminicenducter, field effect transistor ?)
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
    soxten (7th June, 2014)
  6. #4
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    Surprised can do anything with this as hybrid pcb
    soxten's Avatar
    Mar 2013
    Obdsystem, i don't understand you?
    Hybrid pcb?
  8. #6
    Meat-Head's Avatar
    He means this abs is like trying to solder to a porcelain toilet, rather than real curcuit board
    https://encrypted-tbn1.gstatic.com/i...eDeJ1PNZabMnSZ
  9. #7
    soxten's Avatar
    Mar 2013
    Thx Meat-Head, but my pcb is not as the one on you'r picture.
    My is a one with angel gold hair and gel over it.
  10. #8
    Meat-Head's Avatar
    Quote Originally Posted by soxten View Post
    This is what obdsyetems means, I have an ecu the same gold and gel and destroyed it by touching by accident
  11. #9
    soxten's Avatar
    Mar 2013
    Ok
    No mosfet transistor under those 2 aluminium boxes?
    It's hard to find a way to separate abs unit, metal pin ar welded...
  12. #10
    Meat-Head's Avatar
  13. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    gameiruz (5th October, 2016), soxten (10th June, 2014)
  14. #11
    Ok
  15. The Following User Says Thank You to Zmann For This Useful Post:
  16. #12
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    That looks possible - but have you destroyed any wires to that pcb board ??
    See the PCB itself is not designed to be repaired as its not like a conventional pcb - ie open up you computer.
    Thanks ZMann - i take it you've successfully repaired these
  17. #13
    soxten's Avatar
    Mar 2013
    The pcb with angel gold hair is not possible to fix/solder.
    (not by normal tools)
    I repair many Vw abs when alu wire is broken.
    Microscope and no shaking hands is method to solder new wire to pcb.
    Normal pcb is often bad solder problem so they are no problem.
    But this Rover is a h*ll...
    Zmann, how do you take a part those aluminium boxes?
  18. #14
    soxten's Avatar
    Mar 2013
    This mosfet transistor is dead, no ohm on any pin
    Do someone know what sort this is so I can order a new?
    Is it posible to solder the new one back or do I need to weld connections?
    Thx all as helping me!!!
  19. #15
    soxten's Avatar
    Mar 2013
    A mini grinder and a microscope to disconnect this.
