I am getting desperate on this one. It is Stilo 1.9 JTD, 103 kW (140 hp), 1.9 JTD multijet, make year 2004.
The problem is that lots of stuff on instrument cluster aren't working: rev counter, fuel level, water temperature, oil light is always ON, triangle light, etc ... and "loose connection" message. Car also from time to time (rarely) does not want to start due to immo problem.
The Engine Control Module has these errors stored:
U1700 CAN network NCM-NBC, no signal, fatal
U1706 CAN network NCM-NFR, no signal, intermittent
U1601 C-CAN line error, no signal, intermittent
In other ECU's, there are no relevant fault codes. The Body Control Module does not have any communication related fault codes stored. The Proxy Alignment Procedure does not "see" Engine Control Module.
Here's what I did so far:
- checked wiring, looks OK. There is no D4 connector on this vehicle
- put new wires for CAN between ECM and BCM
- put used (from working car) ECM
- put used (from working car) BCM
- put used (from working car) instrument cluster
- put extra earth wire to instrument cluster, which is connected to the earth of BCM
Neither of these are doing any good. Also, I have to say that customer reported everything working OK for a while past week, then going back haywire.
Does anyone have an idea what could be wrong?!
